Post your FTTC line stats & unlocking info
Aha, thanks. Woah how do you know I'm being routed through Sheffield? :P
You're probably correct though. Typical of BT - I remember around April 2011 our Modem restarted and before that we had a 13ms ping to the bRAS and a 14ms ping to the internet. After we ended up with a 13ms ping to the bRAS and around a 21ms ping to the internet - No idea what they did. It only got lower to the bRAS with ADSL2+ because it was on the new WBC network.
No idea why they'd route us up there anyway - Seems very inefficient.
I'm aware of that but I didn't post the results from a Tracert :P. Unless of course it was from my old post.
As for the HG612, it's installed and up and running with the bcm96368MVWG_fs_kernel_HG612V100R001C01B030SP06_unlockedgui-nobtagent firmware!
How's that looking? Any worries?
Day three on Infinity:
It started off on Weds afternoon at around the 45-50MB mark, last night it was slightly better at 63MB and finally this today - it did just peak to the 70MB mark but at the very end it dropped to 69MB again. So far, so good :)
Edit - changed the server to Manchester:
6. Data rate: 20000 / 76917
7. Maximum data rate: 25540 / 76277
8. Noise margin: 9.5 / 6.5
9. Line attenuation: 0.0 / 13.8
10. Signal attenuation: 0.0 / 13.8
Liam
Here is mine using Netgear DGND3700v1 with latest firmware (support inbuilt VDSL mode) it only work on v1 (not v2) running for one hour so far:
are these stats look ok?
Code:
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 38313 Kbps, Downstream rate = 112524 Kbps
Path:	0, Upstream rate = 19999 Kbps, Downstream rate = 79999 Kbps
Link Power State:	L0
Mode:			VDSL2 Annex B
VDSL2 Profile:		Profile 17a
TPS-TC:			PTM Mode
Trellis:		U:ON /D:ON
Line Status:		No Defect
Training Status:	Showtime
		Down		Up
SNR (dB):	 12.2		 23.0
Attn(dB):	 0.0		 0.0
Pwr(dBm):	 12.4		-0.2
			VDSL2 framing
			Path 0
B:		239		237
M:		1		1
T:		23		42
R:		0		16
S:		0.0955		0.3781
L:		20107		5374
D:		1		1
I:		240		127
N:		240		254
			Counters
			Path 0
OHF:		2206066		919497
OHFErr:		0		0
RS:		0		4242081
RSCorr:		0		0
RSUnCorr:	0		0
			Path 0
HEC:		0		0
OCD:		0		0
LCD:		0		0
Total Cells:	560970417	0
Data Cells:	4140960		0
Drop Cells:	0
Bit Errors:	0		0
ES:		0		0
SES:		0		0
UAS:		0		0
AS:		3649
			Path 0
INP:		0.00		0.00
PER:		1.64		3.97
delay:		0.00		0.00
OR:		116.56		64.47
Bitswap:	0		0
Total time = 1 hours 1 min 8 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Latest 15 minutes time = 1 min 8 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Previous 15 minutes time = 15 min 0 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Latest 1 day time = 1 hours 1 min 8 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Previous 1 day time = 0 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Since Link time = 1 hours 49 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
xdslcmd info --pbParams
Status: Showtime
Retrain Reason:	0
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3971)
Medley Phase (Final) Band Plan
       VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:      38313 kbps        112524 kbps
Actual Aggregate Tx Power:    -   0.2 dBm          12.4 dBm
  VDSL Band Status        U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB):	 2.4	 13.3	 20.0	  N/A	 6.8	 16.0	 24.9
Signal Attenuation(dB):	 2.4	 12.4	 18.9	  N/A	 6.8	 16.0	 24.9
        SNR Margin(dB):	 24.1	 23.0	 22.9	  N/A	 12.2	 12.2	 12.2
         TX Power(dBm):	-15.1	-30.4	-0.4	  N/A	 8.1	 7.7	 7.1
xdslcmd info --Bits
Status: Showtime
Retrain Reason:	0
Can someone answer a n00b question?
I am on an ECI cabinet but currently use a HG612 modem (unlocked). I've got a few line errors due to a longish line, so thought I'd buy an ECI modem to try and reduce the errors a bit. I've read that matching modem and cabinet is beneficial :confused:
My question.. I use a LAN address range of 10.0.0.x on my home network, however I've read the ECI is locked down. Would I be able to "plug and play" the ECI modem using my RT-N66U as the wireless access point, without configuring the LAN IP of the ECI?
I don't care about monitoring line stats, but if I can get away with purchasing a locked version of the ECI modem and plugging it in without arsing around with subnets/stuff I don't understand, it'll save me £30.
The modem is WAN side of your router so your internal subnet is irrelevant. Plug it in and it'll work.
If the Asus is your only router then it should obviously be configured as a router rather than an access point.
FWIW my cabinet is Huawei. I have Huawei and ECI modems, and there was no detectable difference between the two.
Yes, the Asus router is configured as a router (as it is now). From my brief reading I think the ECI cabinets are more sensitive to which modems are used, than the Huawei ones. We will see.
Thanks for the quick reply :)
Hi all,
FTTC is finally coming to my area.
I am about ~750m to the cabinet going by the road distance, which matches the route my line takes pretty well.
I'd say my line quality on ADSL2+ is way above average for the line quality around here - it's been re-done a couple of times - so what speeds do you think I should get on FTTC?
Same here.
Cab is full.
I'm on a bit of a crap profile due to me messing about yesterday trying to get my username/password details for Sky.
Code:
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 21651 Kbps, Downstream rate = 67008 Kbps
Path:	0, Upstream rate = 20000 Kbps, Downstream rate = 66566 Kbps
US: (0,95) (880,1195) (1984,2771)
DS: (32,859) (1216,1959) (2792,4083)
Attainable Net Data Rate:      21651 kbps         67008 kbps
Actual Aggregate Tx Power:        6.5 dBm          13.9 dBm
  Line Attenuation(dB):	 1.9	 25.7	 37.4	  N/A	 13.9	 31.9	 47.4
Signal Attenuation(dB):	 1.9	 25.5	 37.3	  N/A	 13.9	 31.9	 47.4
        SNR Margin(dB):	 5.8	 6.0	 6.3	  N/A	 6.1	 6.0	 6.1
         TX Power(dBm):	-5.2	-20.0	 6.1	  N/A	 11.6	 7.6	 6.5
Code:
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 21665 Kbps, Downstream rate = 66784 Kbps
Mode:			VDSL2 Annex B
TPS-TC:			PTM Mode
Trellis:		U:ON /D:ON
		Down		Up
SNR (dB):	 6.1		 6.2
Attn(dB):	 0.0		 0.0
Pwr(dBm):	 13.9		 6.5
			VDSL2 framing
			Path 0
B:		239		236
M:		1		1
T:		21		5
R:		0		16
S:		0.1147		0.3771
L:		16733		5410
D:		1		1
I:		240		255
N:		240		255
			Counters
			Path 0
OHF:		37045269		17025
OHFErr:		353		23
RS:		0		4260225
RSCorr:		0		335
RSUnCorr:	0		0
			Path 0
HEC:		2786		0
OCD:		0		0
LCD:		0		0
Total Cells:	9623068		0
Data Cells:	26642595		0
Drop Cells:	0
Bit Errors:	0		0
ES:		282		23
SES:		0		0
UAS:		23		23
AS:		67213
			Path 0
INP:		0.00		0.00
PER:		1.80		6.12
delay:		0.00		0.00
OR:		106.24		203.67
Bitswap:	12530		61
Mine is pretty good with Billion 8800NL without Openreach Modem. Full stats below:
On going connection: 58D 14H 55M 7S
Code:
xDSL
Mode	VDSL2
Traffic Type 	PTM
Status 	Up
Link Power State 	L0
	Downstream	Upstream
Line Coding (Trellis)	On	On
SNR Margin (dB)	8.9	14.7
Attenuation (dB)	11.3	0.0
Output Power (dBm)	12.4	-1.2
Attainable Rate (Kbps)	90242	32134
Rate (Kbps)	79987	19999
B (# of bytes in Mux Data Frame)	239	237
M (# of Mux Data Frames in an RS codeword)	1	1
T (# of Mux Data Frames in an OH sub-frame)	23	42
R (# of redundancy bytes in the RS codeword)	0	16
S (# of data symbols over which the RS code word spans)	0.0955	0.3781
L (# of bits transmitted in each data symbol)	20104	5374
D (interleaver depth)	1	1
I (interleaver block size in bytes)	240	127
N (RS codeword size)	240	254
Delay (msec)	0	0
INP (DMT symbol)	0.00	0.00
OH Frames	0	0
OH Frame Errors	8278	8594
RS Words	0	4291836
RS Correctable Errors	0	126242
RS Uncorrectable Errors	0	0
HEC Errors	27795	0
OCD Errors	195	0
LCD Errors	195	0
Total Cells	1608166146	0
Data Cells	3690909519	0
Bit Errors	0	0
Total ES	4628	2494
Total SES	0	0
Total UAS	27	27
These look any good?
Code:
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 16957 Kbps, Downstream rate = 70052 Kbps
Path:	0, Upstream rate = 17092 Kbps, Downstream rate = 70818 Kbps
Mode:			VDSL2 Annex B
TPS-TC:			PTM Mode
Trellis:		U:ON /D:ON
		Down		Up
SNR (dB):	 6.0		 6.7
Attn(dB):	 0.0		 0.0
Pwr(dBm):	 13.1		 7.7
			VDSL2 framing
			Path 0
B:		239		237
M:		1		1
T:		21		64
R:		0		16
S:		0.1079		0.4430
L:		17802		4587
D:		1		1
I:		240		127
N:		240		254
			Counters
			Path 0
OHF:		6336049		1524856
OHFErr:		10794		14
RS:		0		3069425
RSCorr:		0		56
RSUnCorr:	0		0
			Path 0
HEC:		379794		0
OCD:		0		0
LCD:		0		0
Total Cells:	1470215748		0
Data Cells:	794388142		0
Drop Cells:	0
Bit Errors:	0		0
ES:		286		11
SES:		19		0
UAS:		19		19
AS:		10805
			Path 0
INP:		0.00		0.00
PER:		1.69		7.08
delay:		0.00		0.00
OR:		113.02		33.86
Bitswap:	3130		122
Total time = 3 hours 26 sec
FEC:		0		0
CRC:		10794		0
ES:		286		11
SES:		19		0
UAS:		19		19
LOS:		0		0
LOF:		0		0
Latest 15 minutes time = 26 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
FEC:		0		0
CRC:		32		0
ES:		20		1
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Latest 1 day time = 3 hours 26 sec
FEC:		0		0
CRC:		10794		0
ES:		286		11
SES:		19		0
UAS:		19		19
LOS:		0		0
LOF:		0		0
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Since Link time = 3 hours 5 sec
FEC:		0		56
CRC:		10794		14
ES:		286		11
SES:		19		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
My line is still in its training period, was 80 now 60. Does anyone have an idea where it might settle based on these stats?
Code:
Broadband Link		Downstream	Upstream
Connection Speed	59695 kbps	19999 kbps
Line Attenuation	18.5 dB		0.0 dB
Noise Margin		7.8 dB		8.8 dB
