Post your FTTC line stats & unlocking info
Well it's been a few weeks now and I'm slightly dissapointed that my download speed hasn't gone back up.
Code:
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 19749 Kbps, Downstream rate = 70320 Kbps
Path:   0, Upstream rate = 19626 Kbps, Downstream rate = 59548 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (880,1195) (1984,2771)
DS: (32,859) (1216,1959) (2792,4083)
Medley Phase (Final) Band Plan
       VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:      19749 kbps         70320 kbps
Actual Aggregate Tx Power:        6.9 dBm          13.9 dBm
  VDSL Band Status        U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB):  2.0     25.7    37.5     N/A    13.9    31.9    47.4
Signal Attenuation(dB):  2.0     25.5    37.4     N/A    13.9    31.9    47.4
        SNR Margin(dB):  6.3     6.0     6.0      N/A    6.3     6.5     6.3
         TX Power(dBm): -3.6    -17.4    6.5      N/A    11.5    7.2     7.2
Code:
# xdslcmd info --show
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 19729 Kbps, Downstream rate = 70324 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        6.4             6.0
Attn(dB):        0.0             0.0
Pwr(dBm):        13.9            6.9
                        VDSL2 framing
                        Path 0
B:              63              238
M:              1               1
T:              64              64
R:              16              16
S:              0.0342          0.3877
L:              18718           5262
D:              943             1
I:              80              255
N:              80              255
                        Counters
                        Path 0
OHF:            180946730               2084838
OHFErr:         5               138
RS:             382033570               683309
RSCorr:         545416          2285
RSUnCorr:       17              0
                        Path 0
HEC:            5               0
OCD:            0               0
LCD:            0               0
Total Cells:    4057487008              0
Data Cells:     1494761425              0
Drop Cells:     0
Bit Errors:     0               0
ES:             1               128
SES:            0               0
UAS:            22              22
AS:             298137
                        Path 0
INP:            3.00            0.00
PER:            1.64            6.20
delay:          8.00            0.00
OR:             116.98          24.50
Bitswap:        44318           626
What should my line be capable of? The cabinet is only 100m or so from my house.
My cab is about 200m away, give or take. Mine started at 80meg, dipped to 60 for a few days and has settled at 71 for a couple of weeks now:
Mine is 200m away and I get this:
Code:
Downstream	Upstream
Line Coding (Trellis)	On	On
SNR Margin (dB)	8.9	15.2
Attenuation (dB)	11.1	0.0
Output Power (dBm)	12.4	-2.0
Attainable Rate (Kbps)	90421	31290
Rate (Kbps)	79987	19999
I was wondering if this seems right:
I had fibre installed a few weeks back now, and after the initial 79999, having to reboot after a day the speed dropped to the 60mb mark.
It's since had a 9.5 days without a resync, and then nothing has gotten any faster.
This is what I've been left with now, and it's had a couple of reboots since.
Code:
 Internet Connection
DSL synchronization status:
Up
Connection status:
Showtime
WAN IP Address:
92.13.*****
Primary DNS Server:
8.8.8.8
Secondary DNS Server:
8.8.4.4
Line Quality
Upstream line rate (kbit/s):
16612
Downstream line rate (kbit/s):
59005
Upstream noise safety coefficient (dB):
5.9
Downstream noise safety coefficient (dB):
6.1
Upstream interleave depth:
0
Downstream interleave depth:
0
Line standard:
VDSL
Upstream line attenuation (dB):
23.2
Downstream line attenuation (dB):
11.5
Upstream output power (dBm):
7.2
Downstream output power (dBm):
13.9
None
DSL up-time:
0 days 19 hours 5 minutes 47 seconds
As far as the cabinet goes, I can actually see it, so would hazard it's about 150 meters away.
Brand new fibre install in the area since 2015.
Should I not be seing closer to max speeds with my stats? Talktalk btw.
How far would you say i am (cable length wise)?
xdslcmd info --stats
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 38437 Kbps, Downstream rate = 102812 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 79999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Mode: VDSL2 Annex B
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Down Up
SNR (dB): 12.1 18.0
Attn(dB): 12.3 0.0
Pwr(dBm): 13.5 1.9
Code:
 Internet Connection
Up
Connection status:
Showtime
WAN IP Address:
92.13.*****
Primary DNS Server:
8.8.8.8
8.8.4.4
Line Quality
16612
59005
5.9
6.1
0
0
Line standard:
VDSL
23.2
11.5
7.2
13.9
None
DSL up-time:
What modem / router are you using out of interest?
Currently TalkTalk "Super router". I'd purchase better if I though the connection would be faster, but too be honest I've had no issues with the connection dropping.
I'm not sure you can see FEC etc errors on this modem, but as far as internet connection goes it reports no errors.
