- 2 May 2011
- Woking
funny thing is it doesn't matter what little label is on a piece of clothing. everybody in town looks the same anyway.
I look forward to seeing your dazzling, unique outfit.
Not superdry but you could get this one? Looks like a bargain to me.
http://www.selfridges.com/en/moschino-metallic-quilted-parka-jacket_148-1000087-45382R64642611/?previewAttribute=Gold
I'd say a little on the large size. I'm 6'3" with stumpy legs and they tend to be a little bit long on the body but fit well on the arms.
Which jacket are you looking at?
If your answering me about the Rab jackets then i was looking at this
http://www.e-outdoor.co.uk/440917/products/rab_mens_microlight_alpine_jacket.aspx
Yeah, sorry should have quoted. I've a Rab Neutrino jacket, so a down one like the Microlight you're after. It's quite long on me and, as I say, I've a long body. By the look of it, it's similar to mine and is a fair bit longer at the back for when you sit down.
Nice choice!
Thanks
Ill prob go for the small then, im 5"8.
Which size did you go for?
I do have a north face vest which is a small and that fits nice so small should be good.
Thanks for the advice![]()
Not very warm
My advice with coats is layers.
Get a quality water proof outer shell (I personally have a Rab Latok Alpine) http://www.gooutdoors.co.uk/rab-latok-alpine-mens-waterproof-jacket-p105299
Something like this will do most of the time then when its as cold as it is now throw on a microfleece or something underneath.
I have a Marmot windshirt i wear under the rab for a bit of extra warmth without being baking hot - http://marmot.com/products/details/driclime-windshirt
When skiing I have -
Base layer, breathable and thin
Mid - Rab PS zip top (stretch fleece type material - http://www.gooutdoors.co.uk/rab-powerstrech-mens-zip-top-p131064)
Inner coat - Marmot windshirt
Outer coat - Rab Latok
Its worse being too warm than too cold, especially if you walk around a lot or exercise. If you are going to be sitting around in -15c or walking in -30c weather get something like a North Face McMurdo or Canada Goose Expedition
Yes exactly, I have a Rab Latok too but I only wear it when skiing or walking!
Plus your suggested combo is 4x more expensive than the original jacket suggestion
I feel slightly ill that someone found that napapijri skidoo for £60, its £250 and im getting it from the Mrs for Xmas!
