The V Core should only be .02v lower in CPUZ than in the bios. Check you have the latest version of CPUZ. This board doesn't need a pencil mod, or indeed any mod.
V Drop = lower CPU voltage in windows than Bios
V Droop = lower CPU voltage when under load.
The bios settings I posted above are the main settings to take note of. Loadline callibration is to counter V Droop.
RAM.
Nope, I mean 0904. Its the Maximus Extreme, available from here:you mean 907?
Weescott does .1.375 vcore in bios sound about right for q6600 g0...should i be tweaking other settings to get it lower and thus reduce remperatures? eg. would tweaking the loadline calibration potentially reduce the vcore or some such?
im nervous that because all the other settings are on auto..things are ;more 'over cooked than they need to be'.
thanks
Flashed my maximus extreme from 0803 to 0904 and its made no difference to performance
Can still only get it stable at 420 x 8. Almost seems pointless having DDR3-12800 now
1.375v is pretty low. You should be able to put up to 1.55v through the Q6600 G0 if you can keep it belows 72c Orthos load.
If you have a stable PC with settings to auto, leave them be.
There are various tweaks you can do (which I listed above) which can effect ram performance and help in pushing the FSB past 450mhz. eg disabling the transaction booster and relaxing it to 3 or more.
Hi guys system is up and running but need some help.
Whats the best way to monitor temperature of cpu from windows? Currently on vista 64..
Thanks
EDIT: i tried coretemp 0.95 but i just get errors all the time when i try to run it
Another prog to try is Everest. Speedfan doesn't work properly.Can anyone advise what voltages would be roughly right for the following combo. also Im using asus pc probe to show voltages and current SB, SB2 FSBT DRAM, DRAM Ref, NB are all showing 4.08v so i guess it dont work - any ideas?
asus maximus formula bios 903
corsair dominator 8500
q6600 g0
apart from defaults.
im running FSB at 400 and vcore at 1.375
the memory is auto at 1066Mhz 3:4, FSBRAM.
every else is set to auto.
I think I ought to manually set those voltages above because if there anything like the vcore - the auto setting is over conservative..
given that the only thing im overclocking is the FSB/CPU can any one advise some suggested voltages for the SB,SB2,FSBT,DRAM,DRAM Ref and NB please, and a utility to confirm them?
thanks
at stock on prime 95 my nb and sb are 47 and 45 0c. and shown in red by asus probe default preferences. I think this is why my board is unstable at 400mhz fsb.
Are these chipset temps higher than they should be at stock? what do others have? is it becuase i dont have a downward facing cpu fan. should I use the optional asus cooler (instructions say not to if the cpu has a cooler).
thanks
