Has anyone found that their HZ26Wi makes a buzzing sound? I'm not just asking for myself, but for someone else on hardforum.com.
Mine doesn't.
My Hazro died at the weekend, just fired off an email through their web form, whats thier support like and the lead time? Having a PC with no screen is kind of a problem.
I've RMA'd a monitor through NEC before and they sent a new one out and i put the old one in the box and sent it back, is this the case with hazro?
Well to be honest, if I don’t hear from them within the next 72 hours, I’ll go to OcUK because legally it’s their problem not Hazro's and they are obliged to sort it out.
EDIT: The PSU seems fine, theres constant power to the screen and the little light is perminantly on. Theres no visible damage that you can see on the outside.
Ah thats bad then.
When my psu went, the green light went as well.
sid
edit/ keep us updated on how this RMA goes.
Well when my power brick went, the green light didn't go off, but it was the PSU they swapped
Mine kept trying to power on and then failing when drawing to much power. Someone else recently had the same symptoms.
The little light on the screen ?
If thats on you could try a factory reset.
With your left index finger on the down arrow use your right index finger to press the power off.
This will reset the monitor.
Dont forget to select the right input when you've done this.
Just like clock work the thing has died again. The buttons no longer work and its stuck on. Its definatly going back.
