- 23 Dec 2009
- RG8 9
Happy with that.
Yes, that's exactly the reason why.I'm getting half the speeds that you guys are, would the fact that i'm only on a Sata II 3Gbps port bottleneck my M4 256Gb that much.
Looks at some results, my drive seems a little slower compared to some?
Before installing windows did you select AHCI in bios?
Pretty sure I did.
What controller is it attached to?
The Intel one on my P8P67 Pro B3.
I was able to tweak the RAID setup of the 2 x 64GB M4's and was able to squeeze out some better numbers than I got before.
System:
- i2500k CPU running at 4.2Ghz overclocked (stock volts)
- 2 x 64GB Crucial M4 SSD's running firmware 0009
- 8GB Kingston PC10666 DDR3 Ram (HyperX Blu)
- Gigabyte SoC GTX460 1GB Graphics Card
- MSI P67-G45 B3 Motherboard running latest beta bios.
- Antex TX650W Power Supply
- Antec 300 Case
Downloaded the firmware but for the life of me i dont know what file i need to create the iso help![]()
ImgBurn will let you burn the ISO to a blank CD/DVD/BD. Then you just boot from it.Downloaded the firmware but for the life of me i dont know what file i need to create the iso help![]()
Not sure about the reads but higher capacity drives will have faster writes due to more channels being used.Why are my read speeds down compared to most and my write speeds higher than others? I'm guessing it could be due to the size of the drive but surely I should still see 500MB/s+ Read?
This is a 240GB M4 that came with 0009 already on it.
so when you install WIN7 with SSD always AHCI enabled?
Hello Chaps. Might be a complete moron here but Just wondering - Wouldn't the Corsair Force series 120GB/240GB be a better drive for its price and its write speed? Or am I missing something?
apologies If i'm asking a silly question. Just trying to work out if I should buy this or the Corsair 240GB
