- 10 May 2004
- Middlesex
Do all your phones make a rattle when you hold it up with one hand and then tap the apple logo / camera lense on the back with your fingers?
Mine rattles something shocking, need to know if all yours do it and if its loud or noticable at all?
Nope and all the location things are disabled apart from like one or twoAre you using such things as location based alarms and things? Because if you do the GPS has to stay active all the time which really drains the battery.
I have a location based reminder set on mine. If this is the cause of it then I'm gonna sell mine. It's ridiculous that a feature of the OS can cause the battery life to be basically unusable.
My battery has been shocking today. It was on 6% by like 4:15, taken off charge at probably 6:30am... It went down from 13% - 6% within 20 minutes :S I had done a restart earlier in the day as well. Wasn't using the phone any more then normal either.
Now, you may notice something different about the last shot in that set:
http://farm8.staticflickr.com/7143/6681047471_1120633d1b.jpg[img]
Much better :D
It's still early days, but it looks like iOS 5.1 beta 3 has done the trick.[/QUOTE]
Is that honestly the difference in battery usage? :eek:
Notice the massive difference in usage...
