# xdslcmd info --show
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 22675 Kbps, Downstream rate = 70660 Kbps
Path:   0, Upstream rate = 10000 Kbps, Downstream rate = 39998 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        16.1            14.5
Attn(dB):        0.0             0.0
Pwr(dBm):        12.6            6.9
	# xdslcmd info --pbParams
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 22687 Kbps, Downstream rate = 70660 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3939)
Medley Phase (Final) Band Plan
       VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:      22687 kbps         70660 kbps
Actual Aggregate Tx Power:        6.9 dBm          12.6 dBm
  VDSL Band Status        U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB):  4.5     24.1    36.5     N/A    12.1    30.0    48.7
Signal Attenuation(dB):  7.5     23.3    35.6     N/A    12.1    30.0    48.7
        SNR Margin(dB):  14.3    14.5    14.5     N/A    16.0    16.1    16.1
         TX Power(dBm): -4.1    -22.4    6.6      N/A    9.8     8.0     3.9
	I've had BT Infinity for about 3 hours now. A couple of modem reboots as I unlocked it.
I'm connected to the HH via Powerline 200Mbps @ ~75Mbps
I think my cabinet is ~450m (according to google maps)
speedtest.net is reporting ~22.5/~7.5
Is this speed OK?
IP profile?
thing is, is he using wireless? whats bt speedtester site say etc.
ahhh, home plugs, the 3 re boots may have brought in the dlm
Do you mean the line that says '17a'?
http://speedtester.bt.com/
The full java-based test will tell you the IP profile. Are you using wired or wireless?
I would try a direct connection to the hub to see if you get the full speed.
I see what brand of home plugs are they?
How do I connect to to the modem through my router? Do I have to put in a NAT statement or something? Or just put them on the same subnet?
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 32287 Kbps, Downstream rate = 101040 Kbps
Path:   0, Upstream rate = 10000 Kbps, Downstream rate = 39999 Kbps
Attainable Net Data Rate:      32287 kbps        101040 kbps
Actual Aggregate Tx Power:        6.6 dBm          13.2 dBm
  Line Attenuation(dB):  3.9     19.6    28.3     N/A    10.3    24.5    38.2
Signal Attenuation(dB):  6.5     18.2    27.5     N/A    10.3    24.5    38.2
        SNR Margin(dB):  20.8    21.1    21.3     N/A    24.8    24.4    24.8
         TX Power(dBm): -5.7    -30.1    6.4      N/A    10.2    7.9     6.2
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 32323 Kbps, Downstream rate = 101040 Kbps
Mode:                   VDSL2 Annex B
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):        24.7            21.3
Attn(dB):        0.0             0.0
Pwr(dBm):        13.2            6.6
                        VDSL2 framing
                        Path 0
B:              240             239
M:              1               1
T:              64              35
R:              14              0
S:              0.1917          0.7622
L:              10644           2519
D:              19              1
I:              255             120
N:              255             240
                        Counters
                        Path 0
OHF:            1025896         236595
OHFErr:         0               1
RS:             65673485                3670537
RSCorr:         23              0
RSUnCorr:       0               0
                        Path 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    242991356               0
Data Cells:     3368567         0
Drop Cells:     0
Bit Errors:     0               0
ES:             0               1
SES:            0               0
UAS:            17              17
AS:             3157
                        Path 0
INP:            0.00            0.00
PER:            3.06            13.33
delay:          1.00            0.00
OR:             83.48           37.18
Bitswap:        3               11
	I'm getting terrible jitter though.![]()
