Pics!!![]()
give him time, he's probably still making it burp by backing off the throttle.. that amused me for 4 years and 2 cars!
got the chip in the passenger door repaired and the colour is perfect (EO), it cost the guy who damaged it just under €1000. It was the same Ford i used for the full rear respray the last time they took 8 weeks and had to fly a colour specialist over from Ford Germany.
They also had a look at my boost issue and re-calibrated the car and it seems to be sorted.
We replaced the Boost solenoid a few weeks back but this did not fix it, also no pipe cracks or loose pipes and it was not the oil diaphram.
Yes mate, you need a special cable though. It should have a 3.5mm jack and usb connection with the other end being for your ipod / phone. Oh and congrats again![]()
Don't believe the trip on your computer, mines at least 2 below what it actually gets (I use FuelLog for Android).
If your first month is anything like mine, you'll be spending at least £500 on fuel, get a Fuel Loyalty card if you don't have one already, I've put over 800 litres of fuel in the past 3 months, V-Power club here I come![]()
Yeh I have a 3.5mm AUX port and a USB port. I understand the AUX port is basically like plugging my iPhone into headphones i.e I won't be able to change songs from the centre console. What is the USB port for?
Haha uh oh! Good job I have a shell loyalty card
Do you all put shell v-power or equivalent in or just the normal stuff?
Also I'm going to be fitting a decat pipe this Saturday, anyone got a useful "How-To"?
Jack car up, unclip sensor, try undoing rusty bolt, round off the rusty bolts on the cat, get the angle grinder out, grind the bolts off, remove cat, use a pipe spanner to remove sensor from cat, install sensor into decat pipe, bolt back on to car and clip the sensor back in, put car down, job jobbeed![]()
Is there a way to get this USB connection if it doesn't exist? Knowing ford they tend to have all the wires there hidden, but wont have the USB slot accessible.
Anyone tried it?
I presume installing the sensor back onto the decat pipe is an easy job then?
