After using it for a bit now I've decided the onboard sound is rubbish.
Half tempted to ditch the samsung ram and maybe pickup a pci-e soundcard to replace my aging pci x-fi.
After another lockup on Friday night (high pitched sound + freeze), i took the X-fi fatality fps PCI card out and installed onboard plus the x-fi emulation software.
I definitely noticed a difference. The sound is fine (but not great) in BF3. I can still pinpoint sounds around me and my score has not suffered as a result.
But i do notice that there feels like gaps in the 360 degree sphere of sound and you have to turn slightly towards it to hear it properly.
With the X-fi it felt the 360 arc of sound was complete (dont know if that makes sense
Definitely a lack of bass as you say broo.
I am afraid to jink myself but i have had no lockups in the 3 days (12/14 hours of gaming) since i took the card out.
So either there is an incompatability issue with the card or an issue with the PAX drivers i was using.
Were you using Creative's drivers Broo?
Everything is back at stock including VTT. (i just raised VTT and DIMM voltage to see if it helped with the freezes. It did not)
BCLK is at 100.1 though
I will play BF3 tonight and if no freeze then that will be the longest i will have went without a freeze.
If the sound card was the issue then i may look into getting a PCI-e card also
