Do chins - much more fun, and you get a back work out too!![]()
I do![]()
Having big biceps doesn't bother me, they will come in time.
Hello all
I require your clothes, lifting straps, and your dipping belts.
(notsrs on the clothes part)
Can anyone spec me babeh? Nothing majorly expensive, just enough to last a fair while
Cheers for the links all.
Syla5, shall I just get the £2 ones off of Amazon?
There not padded so its your call. If you go for amazon ones i will pass as i would prefer some padding around my wrists, the whole point of me needing straps is so that i dont have to rely on grip for RDL's etc past a certain point, so a little padding might be beneficial.
Yup
Use Oly bars with weights - they are longer, and the way it "feels" will be completely different. Sure the weight is the same, but it's a shorter bar, and as such will not have the same effect - less leverage too as well as being thinner.
Not quite what I want it to be yet. (Although had done 5x5 before it)
kd
Hello all
I just bought a length of chain and use that with a carabiner. It cost about £3 and is supposedly rated to 140kg. Ghetto style yo!
