Shamelessly robbed from the MLR:
Evo VIII (Chasis number CT9A 020 XXXX for JDM/FQ models)
UK Models
Evo VIII 260
• 2 cats (1 in down pipe, 1 in "normal" position)
• 5 speed gear box
• 9.8T housing (some with single flapper wastegate)
• Slightly modified Evo VII ECU (four plug)
• Euro Style Recaro interior c/w rear adjustable headrests - Leather / Suede option at cost
• Non-folding electric wing mirrors
• 8 MR pistons & head gasket
• No rear wash jet/wiper
• Small spoiler with brake light incorporated
• No SAS
• UK style Number Plates
• Integrated Fog lamp in rear light cluster
• Single Din dash
• Kenwood 6 speaker stereo system
• Large Battery
• Bridgestone Potenza tyres
• Non HID Headlights
• 3x3 ISOfixPoint Rear Seat Belts
• 17 digit chassis number on a plate riveted to the dash
Evo VIII FQ 300 – as 260 plus:
• Upgraded blue/black interior inc. narrower seats
• HKS Superdrager catback with HKS downpipe exhaust
• 3 Plug ECU
• Secondary Air System (SAS)
• More aggressive cams
• Folding electric mirrors
• Double Din stereo slot
• Climate Control
• Fog light in bumper
• Japanese-style front number plate holder
• Only one catalytic converter
• HKS Hardpipe kit
• HKS panel filter
• 6 speed gear box
• Yokohama Advan A046 tyres
• Rear brake light in windscreen
• Larger carbon spoiler (body colour paint on outer uprights)
Evo VIII FQ 330 – As VIII FQ 300 plus:
•upgraded black alcantara/leather interior
•piggy back ecu
•restrictor in pipe connected to wastegate actuator
•smartnav
Import models
Evo VIII GSR – As UK VIII FQ 300 less:
• HKS Superdrager exhaust
• Foglight in bumper
• FQ Badges
• HKS Hardpipe kit
Evo VIII RS – As Evo VIII GSR plus:
• 5 speed box
• Stronger rear diff (non S-AYC)
less:
• Air Con
• Alloy wheels
• Recaro seats
• Electric windows
GSR deleted items available as optional extras.
Evo VIII MR (Chasis number CT9A 030 XXXX)
UK Models
Evo VIII MR FQ 300 – As VIII FQ 300 plus:
•10.5T (single flap) housing
•upgraded cams
•MR seats & door cards
•carbon effect dash inserts
•dark brushed steel steering wheel
•Bilstein shock absorbers
•aluminium used in roof & side door beams
•Team Dynamic (gunmetal) alloys
•black backing to front & rear lights
•13 row oil cooler
•twin boost solonoid
•optimisation and reinforcement of the oil channels in the pistons
•uprated 5-ply head gasket
•added tension in piston rings, v shaped groove in second land of pistons
•reduced weight S-AYC diff (alu casing), higher strength hypoid gears, operates even when ABS is activated.
Does not have:
•HKS Superdrager exhaust
Available in gunmetal grey, not available in black, yellow or blue.
Evo VIII MR FQ 320 – As VIII MR FQ 300 plus:
• HKS panel filter
• HKS hardpipe kit
Evo VIII MR FQ 340 – As VIII MR FQ 320, plus:
• Piggy back ECU
• Black leather/alcantara interior
• Optional smartnav
Evo VIII MR FQ 400 – As VIII MR FQ 320, plus:
• Forged engine
• Limited edition of 100 Custom built Garrett GT Dual Ball bearing turbocharger
• Owen Developments custom manufactured cast s/s
exhaust manifold & elbow
• Omega forged pistons
• HKS forged con rods
• HKS 680cc injectors
• Zytec ITP116 high pressure fuel pump
• HKS 1.6mm steel head gasket
• Motec M800 OEM ECU
• HKS iridium spark plugs
• Jan Speed High Flow Sports Cat
• Alcon 240mm high clamp mode, HD
clutch with Cera-metallic 6 paddle sprung centered drive
plate
• HKS High Strength Head & Big End Bolts
• Alcon Mono6 Brake Kit with Monobloc 6 pot road caliper &
343mm curved vein disc, aluminium bell,
Ferodo DS2500 pads
• Ralliart carbon effect, electric Aero Mirrors
• Carbon fibre front lip
• Carbon fibre rear vortex generator
• PIAA High Performance light & wiper upgrade
• Half leather and FQ400 Logo in Seats optional extra
• Gloss black Team Dynamics lightweight alloy wheels
Import models
Evo VIII MR – As Evo VIII GSR plus:
• 10.5T (single flap) housing
• Upgraded intake cam
• Modified pistons
• MR interior
• Bilstein shock absorbers
• Aluminium roof
• BBS alloys
• Black backing to front & rear lights
• Available in gunmetal grey, not available in black, yellow or blue.
Evo VIII MR RS (5 speed) – As Evo VIII MR plus:
• 5 speed box (6 speed optional)
• Silver backed lights
less:
• Uprated intake cam
• 10.5T hotside
• 5 ply headgasket
• Modified pistons
• Air Con
• Alloy wheels
• Recaro seats
• Electric windows
Evo IX (Chasis number: CT9A 040 XXXX)
Import models
Evo IX GSR – As VIII MR plus:
• Mivec
• Larger compressor housing diffuser (16G6C)
• No spacesaver spare tyre
• Gloss black backing to front & rear lights
• Rear diffuser bumper
• Restyled front bumper with twin oval air inlets
• Different size rear oil return to block
• Plastic spoiler uprights
• Evo IX Enkei Alloys.
Available in Cool Silver, Flame Red, Electric Blue, Frost White, Amethyst Black and Solar Yellow.
Evo IX GT – As IX GSR plus:
• Magnesium Compressor wheel
• Titanium turbine wheel
• 5 speed gearbox
• GT interior
• RS Front Diff Set Up (non S-AYC)
• Improved drive train
Less?:
• Air conditioning (Opt.Extra?)
• Electric Windows (Opt. Extra?)
• Remote Central Locking (Opt. Extra?)
Evo IX MR – As IX GSR plus:
• No additional alarm fob (built into key);
• Ralliart Wing Mirrors (on some models)
• Carbon front lip
• New turbo with titanium aluminium alloy turbo fins & reduction in compressor inlet diameter (15.5)
• 17in, 11-spoke Speedline Turini alloy wheels
• Privacy glass
• Lowered ‘Eibach’ coil springs – 10mm front / 5mm rear
• Aluminium door sill plates
• Piano black dash inserts
• Available in Gunmetal Grey, not available in Black, yellow or blue.
Evo IX MR RS – As IX MR plus:
• 5 speed gearbox
Available in Solid White or Solid Red.
Less:
• Air conditioning (Optional Extra?);
• Electric Windows (Opt. Extra?);
• Remote Central Locking (Opt. Extra?);
• Recaro Seats;
• IX Enkei alloys (comes with steel wheels).
Evo IX RS – As IX MR RS plus:
Only available in Solid White?
UK models
Evo IX FQ 300 – As IX GSR plus:
• Foglight
• PIAA lights and wipers
• FQ badges
• HKS panel filter
Evo IX FQ 320 – As FQ300 plus:
• HKS hardpipe kit
• Keyless entry
• Ralliart sports pedals
• Puncture repair kit
Evo IX FQ 340 – As IX FQ 320 plus:
• SmartNav
• Ralliart Leather/alcantara seats
• Remap
Evo IX FQ 360 – As IX FQ 340 plus:
• Race Cat
• Ecutek remap
• Speedline 5 spoke alloys
• Triple Gauge Din Unit: battery voltage, Oil temp. and Boost (reads up to 1.5bar)
• Uprated 225 l/ph fuel pump
• Carbon vortex generator
• Carbon front splitter
Evo IX MR FQ 360 – As IX MR plus:
• Race Cat
• Triple Gauge Din Unit: battery voltage, Oil temp. & Boost (reads up to 1.5bar)
• Ecutek remap
• Leather & Alcantara seats with ‘IX MR’ logo (leather delete option)
• Carbon Vortex Generator
• 6 Speakers as standard
• SAYC changed to give increased torque differential across rear axle
• Uprated fuel pump
• "By HKS" badge on boot
• Available in Cool Silver, Gunmetal Grey, Flame Red, Pearl White, not available in Black, yellow or blue.
