Wow I can't believe how small the original intercooler is! Got my airtec gen3 put on today and the size different is crazy!
For reference, mine cost £12,000, is a 59 plate with all those options bar the Sat Nav.
I skipped that as I have a Tomtom. I also got the MP260 upgrade in that price.
What's everyone's thoughts on the ST?
Just updated the bluetooth module on mine, can now use my old ipod without having to use an AUX cable! Woo!![]()
Did you have OEM bluetooth?
I've seen a few STs that fall into my price range and will hopefully be having a look at them today. Is there anythng in particular I should be looking at, any common problems that may need to be resolved.
The cars in question are 60 plate ST-2s if that makes any difference.
First off, try and find an ST3.
Secondly, the engine should be solid, common problems found in the earlier years of the ST should have been fixed for a 60 plate.
You are generally just looking out for wear and tear. Check the steering wheel, is it wobbling too much? Then the bushes are probably shot.
Has the car been re-mapped? If so, check the clutch, put it in 4/5th about 30mph and boot it, if it slips, you need a new clutch...
The only issue is see with the ST-3 is the 2 seats in the back. What are the major advatages to having an ST-3 over an ST-2 (leather seats etc aren't a deal breaker for me)
Servicing: Routine is £99 with Ford (same with a 1.8, except major service is more on the ST)
Parts are generally very cheap, and I've had nothing go wrong *touch wood* so far, other than front bushes (£100) and CV joint (£70), these are common issues due to wear and tear (having lowered springs makes it worse too)
That'll just be the Year 1 service, Year 2 is around £250-£300 if I remember rightly, and Year 3 is around £400.
