At the moment I am downloading BF4 onto my HD 5970 system for a bit of quadfire action.
Do you guys recon it will run and if so at what settings.
I will be using my TV as a monitor so the max resolution will be 1080p
Should be ok at high i reckon with a 1gb card.
Anyone managed to get fraps running without crashing it?
It runs fine with my Titans, 290Xs and 690s unless something has changed in the last couple of weeks.
Yep, by disabling afterburner.
I know what you mean, but i disabled it just so i could get a quick bench in when i got the 780.It was running fine for me before the dlc patch. Not no mo...
Bugger... I needs muh Ab.
Just tried it and GPU-Z still shows them as being where they should be.
