Is it just me or is Battlelog broken.. i cant log into it. Page isnt loading.
Sums up the whole broken BF4 thing![]()
I hate to say this, because ive had no end of problems recently with this game. However for the past week, BF4 has been working very well for me. Mantle is the best its ever been for me. Long may it continue. (probably just jinxed myself)
That didnt answer my question tho.
Anyway EA have given me a new error message..
*Problem contacting EA Login, please try again in a while*
Like i said in game the other day.. EA cudnt organize a **** up in a brewery![]()
Yeah sorry mate.
I just tried to login and access battlelog and had no problems.
Shut down origin. Clear browser cookies. Restart pc. Try again.
Seems lots of users cant log in today, usually a sign of an update coming soon. Patches, dlc, even a simple bl plugin causes issues.
Takes me about 5 minutes today (literally) from clicking play in Origin until BL loads - usually takes like 3 seconds max.
Just tried Mantle again under the 14.4 drivers for the first time since the initial mantle launch after getting fed up with the CPU spiking.
However my mantle performance is terrible, under D3D I average 120fps and under mantle i struggle to hold 70. I remember reading some mantle settings that can be altered to do with frame pacing which if left on the default settings has a huge FPS hit, could anyone advise.
Cheers
His sig says 7970 does mantle use more then 3gb?
LtMatt said:System Specs
2700k@5ghz
16GB DDR3 2133Mhz
290P Crossfire @1000/1250 (stock 975/1250)
Win8.1 64BIT
14.4 WHQL
Ultra Preset +x4 AA
1080P DX11.1 - 290P @975/1250 In This Run
1080P Mantle API
1440P Mantle API
1440P Ultra Preset +x4 MSAA - Mantle API
140% Resolution Scaling = 3584x2016
	The resolution scaling doesn't really equate to true 4k performance I don't think, I had varying results from doing this and setting downsampling via the NV control panel. Your average frame times appear to be fairly high compared to mine. Could that be down to the CPU?
I don't know about that. It certainly makes the gpu's work a hell of a lot harder but i don't know if its as demanding as true 4K. I possibly would've thought it might be similar as it has to render it then down scale it, seems like more work. I could be totally wrong about that though, just a guess on my part.
I doubt its cpu related at these settings, very much gpu limited at this resolution i think. Anyway you have a better cpu than me. Perhaps the difference is Mantle? I could run a DX11.1 bench to compare i suppose.
