So I've just flashed the P6T SE with a P6T WS Pro bios and so far it looks like it's cured the cold boot issue I had.
Interesting can you email me the bios please ?
Had anyone tried the Gigabyte GA-X58A-UD3R rev 1 board with these chips?
I have one running a i930 and would be interested in upgrading to a X5570 but am unable to find if my board will run these. Gigabyte site does not list these Xeons as compatible.
I'm using a Gigabyte GA-X58A-UD3R rev 2 so I don't see why your V1 wont.
Does it list the 980/990x ?
Or the 970?
If it does there's a good chance it will work![]()
Yes, it supports the B1 130w versions of the 970/980X/990X Gulftown CPUs.
Not sure if Westmere will be supported though.
Thanks, have taken a punt on an X5670!
What are your auto volts at 4GHz in CPUz under load?
1.302v since the bios flash using extreme on intel burn test. With the P6T SE bios I had it at 1.320v to get it stable.
Can anyone help with a problem please.
I've clocked my x5650 to 4.1ghz at 1.28 vcore but when using HWmonitor during gaming i am seeing the voltage spike up to 1.7 volts. It doesn't do this in IBT or Prime95, it only goes up to 1.303 volts and is stable for 5hrs.
Can this be right and if so how do i set my cpu voltage to not go over a certain voltage? i have manually set the voltage 1.28 so there must be some other setting that is auto changing the voltage.
Help!
Pretty good volts![]()
Cheers mate, I'm still cooler shopping but I'm limited to a height of 16cm and I've not had good experiences with the last two aio's I had, h55 and h80. Considering sacking the case offl, it's shockingly bad for cooler options unless I get creative with the dremel and move the hdd cage back a few cm so I can get a 240mm rad in there. Corsair Carbide Series SPEC-01 wtf was I thinking, oh yeah £38 haha
I've heard nothing but bad of Corsair's lower priced products. My lady and I both got Raptor mice for £16 each. Mine lasted about a week, then the scroll wheel stopped working and just jerked the web page. A month in hers snapped off at the USB socket.
Must say it's put me off for life tbh. My mate had a 01 and said it was utterly lousy for managing cables.
See what CPUz reports instead.
