***THE BF4 BENCHMARKS THREAD***
Can i play? :D #Flex
X4
Sorry for the crappy handheld recording. ;)
No, you can't and I want Arnie back :mad:
Corrected the link. It's been a while since i posted a youtube video here. :o
Lol.... ^^^^ :)
I managed to get my CPU stable at 4.8Ghz, but its not ideal, 1.52v, which in its self is not a problem, the problem is my Cooler Master Seidon 120V can't deal with the heat that voltage results in long term.
I need a better cooler...
Thing is the i5 2500k I had running 4.8ghz very easy. but the i7 2600k I believe I would need to disable Hyper threading to get 4.8..
I also changed my stock h80i fans for more quite fans Gentle typoons but these dont keep the temps as low. Before with stock fans I used to sit about 50c @4.4 now its 60c still acceptable though.
Nice :D
See you now have 80fov also.. I didn't know till today having higher FOV draws extra effects on screen.. I knew it was more demanding but never knew you get more lighting.
All good fun :)
And FOV stands for Field Of View, so the higher it is, the more details will be drawn, which will impact performance. I am not good enough in truth and left it to what BF4 had it set and only moved it to match your settings. Still looked the same to me :D
Doesn't increasing FOV change the shape of the picture, IE squeezing more into the same space, so it ends up a bit squashed?
X4
At 4K i tend to use 100FOV or 105FOV. You can see a hell of a lot on screen, but it does not look out of place at such a high resolution with so many pixels on screen.
Yeah, if you over do it like some people run 100+ lol 80 or 90fov is the max I would say.. This at 1080p it may change at high res like 100+ at 1440p for example might seem fine.
Thought so, i think i tryed it once at 1080P, ended up with a Fish-Eye effect...
Ohhh fair and you should run the same as me and Shankly to see what is what. Very surprised at the massive drops you were getting there. Was it heat throttling or just the game?
