So I've applied for the free upgrade on a few machines.. Will I get a key for each one? How does it work?
lol is it even going live at midnight? I can imagine it will just start slowly rolling out over the next few days.
Perfect, exactly the answer was looking for. I registered ages ago but never bothered to upgrade at the time due to reports of how buggy it was.
Now I really need to do an OS reinstall so wanted to go this route rather than stick 8.1 on and have to do the fresh install shortly after.
Will probably do the upgrade tonight ready
EDIT: just tried the installer for the RTM build to take a look and asks for a product key, would i simply enter my 8.1 key here?
I just ignored it, you can click skip if I remember correctly? I didn't enter a key once.
if you upgrade to win 10 can you still down grade back to win 7 ? if you don't like win 10. cheers.
so will windows 10 have a usb fresh install link ?
Found this guide from MS on how to hide or block windows update- drivers.
http://microsoft-news.com/how-to-hide-or-block-windows-updates-or-driver-updates-in-windows-10/
Pre-loaded here too, without me doing anything or being in the know lol.
Windows 10 RTM has been working really well for me over the last couple of weeks but one little problem I have not worked out yet is when I click the 'shut down' button it attempts to do so but then returns to the desktop after a few seconds or so.
I can select restart and it does it thing fine, but shut down does not seem to work right.
Anybody know why this happens and what the cure is?
