https://videocardz.com/67444/colorful-geforce-gtx-1080-ti-igame-features-lcd-display
needs Debug i think on there
just noticed the 2x8 pins are connected via the bottom !
Looks a bit tacky/naff, just a gimmick. I'd rather these companies put more effort into the actual cooler performance than wasting it on more flashing lights and bells.
Anyone know if EVGA is ok with cooler removal or is it just Gigabyte?
Thanks, no sticker on it then?Yep, they allow you to remove the cooler.
There is but its just to know if you HAVE taken the cooler off. EVGA are sound.Thanks, no sticker on it then?
Placed an order for the EVGA FE elsewhere whenever they come back in stock, now i need to order the Eiswolf cooler along with the 240mm radiator.
Won't be upgrading again until the next high end Ti card now.
Not sure if serious but seriously deluded if you think you would get anywhere near 50fps extra!guys what am i doing wrong? I just installed my brothers 1080ti with fresh drivers, anyway benched wildlands on 1440p max settings and all we get is a 15-20pfs difference, did the bench 4 times, exactly the same system same settings, also the witcher 3 on max settings is only getting 15 fps difference, so installed the classy 1080 back in, just one card benched it again to compare with the 1080ti and its only behind by an absolute minimum.
The 1080 classy is NOT overclocked and benched at stock levels.
We was expecting at least a 50fps difference, are we expecting too much ? So is it early drivers or do we need to overclock the 1080ti?
same thing happened with my 1070 sli vs 980ti sli kingpins, I only got an absolute minimum.
Plz advise on how i can get better performance.
A 15-20 fps increase at 1440p moving from a 1080 to a 1080 Ti? That sounds about right. The card isn't twice as fast, it's (if memory serves me right) about 35% faster. So if you were getting 60 fps, and you're now getting 75 - 80, that's about the increase one would expect.guys what am i doing wrong? I just installed my brothers 1080ti with fresh drivers, anyway benched wildlands on 1440p max settings and all we get is a 15-20pfs difference, did the bench 4 times, exactly the same system same settings, also the witcher 3 on max settings is only getting 15 fps difference, so installed the classy 1080 back in, just one card benched it again to compare with the 1080ti and its only behind by an absolute minimum.
I'm looking for good quality/reliable, quiet cooler, and good customer service in case something goes wrong.
