The Pascal GTX 1080 Ti Owners Thread
1 Apr 2010
What are you actually achieving by adjusting the voltage curve?
Higher overclocks mainly and it can help with avoiding perfcaps. Highest overclock before messing with the voltage curve was 2088Mhz and now I can hit 2126Mhz, I might be able to get a touch more but haven't tried yet.
18 Oct 2002
scone: simply adding voltage to my card results in a hard lock, if i use a curve it remains stable beyond 2100mhz. takes a bit of trial and error but it's worth it.
4 Nov 2012
Does this fan curve look too aggressive :o? This is the first time I have ever bothered to mess around with fans+overclocks, generally just leave them all on the defaults. Power limit 100 still, core clock +50, memory still at 0. Still seems to settle around 1962-1987-2000MHz in games. Imagine I would have to mess around with the power/voltage to push for more and also waterblock?
Man of Honour
OP
21 May 2012
Dalek flagship
Have you measured the performance when tweaking the curve.
I have tried several times and I find it is a bit like the Emperors new clothes. I get higher clockspeeds but no extra performance.
18 Oct 2002
I have a hunch that on the FE it comes more down to how much volts your chip needs. If its a good chip, it will draw less volts and hit the power limit less and it will give you higher scores.
If the chip is not so good then it will allow you to set the clock but as it requires more power to keep it there, you will hit the power limit more.
In Superposition yes I saw some extra perf. but only up to a point, I think anything beyond 2100 is a minefield. Gregsters card is faster at roughly same clock speed but he has better power.
Have a go at setting a 1950 boost clock speed and see what volts you chip needs to be stable. I will be giving mine a go at some point over the weekend on the FE to see how good the bin is ready for the arrival of the HOF :)
3 Jul 2014
So I got my Strix 1080ti OC and have to say I am very impressed with the card so far. Excellent build quality, very quiet and very cool. My last Nvidia card was a hybrid and I honestly don't think the difference in noise is that great, certainly not worth AIO extra cost so far.
The card overclocks well but need some more time to play with it and get it stable...unfortunately I have to travel for work for a few days...but glad I got the card earlier than waiting for the FTW and had some time to play...
Thanks for the great service OCUK and ASUS
13 Nov 2014
Sign me up :)
c1ZIRNv.jpg[IMG]
Am i not supposed to have both 8 pin plugs plugged in from my PSU?!
You only have one plugged in im getting worried hehe
2 Oct 2012
Cheers mate, I didn't try any further but will give it a go when I get some free time. :)
Hows your new build coming on?
Thanks slayer, no mods on this card, its totally stock only thing I have done is add a water block.
2088 is a very good clock, that's what I was getting before I tried the voltage curve and I was pretty chuffed with that clock speed.
Here is my voltage curve.
Thanks Razor Time :) I tried to mimic that curve but it does not help me unfortunately. I still seem to hit power limit and tbf looking at GPU Z And the Perfcap it provides 3 different colours lol. Weird. I just think you got a cracking card/chip!
13 Nov 2014
Yea you are lol, id be surprised if it booted properly because of the way the card is designed. It will be able to tell there is no power coming through one of the 8pins.
Sweet my cards working fine just wondering as i plugged an extra 8 pin into it whereas he only plugged in the one.
Thing didn't come with instructions lol.
Man of Honour
OP
21 May 2012
Dalek flagship
Exciting!
Welcome and on TROH.:)
The Roll of Honour.
Date 06/05/2017, Make Zotac Amp Extreme, CaptainRAVE, Link
Date 04/05/2017, Make Gigabyte Aorus, zola25, Link
Date 04/05/2017, Make Asus Strix, Joe_Easy, Link
Date 03/05/2017, Make Palit Super JetStream, Telecaster, Link
Date 03/05/2017, Make Asus Strix, Monkeh, Link
Date 03/05/2017, Make Inno3D Founders Edition, offmyed, Link
Date 01/05/2017, Make Asus Strix, HaloUK, Link
Date 30/04/2017, Make Asus Strix, liammorris1990, Link
Date 29/04/2017, Make Asus Strix, N0ddie, Link
Date 29/04/2017, Make KFA2 Founders Edition, SupraWez, Link
Date 26/04/2017, Make Zotac Amp Extreme, EPCCare, Link
Date 25/04/2017, Make Zotac Amp Extreme, Kiro-San, Link
Date 23/04/2017, Make Zotac Amp Edition, TomDD, Link
Date 22/04/2017, Make EVGA Founders Edition, .:SAmSuNG:., Link
Date 22/04/2017, Make Gigabyte Gaming OC, digitalx, Link
Date 22/04/2017, Make MSI Gaming X, Atli, Link
Date 20/04/2017, Make Asus Strix, Mayh3M, Link
Date 20/04/2017, Make Zotac Amp Extreme, SupernovaUK, Link
Date 20/04/2017, Make Asus Strix, ThereIs0nly0ne, Link
Date 20/04/2017, Make MSI Gaming X, tyler_jrb, Link
Date 20/04/2017, Make Asus Strix, wingnutta, Link
Date 19/04/2017, Make MSI Sea Hawk, WhiteHawk77, Link
Date 19/04/2017, Make Zotac Amp Edition, Bindlestiff, Link
Date 19/04/2017, Make Gigabyte Aorus, LHM, Link
Date 15/04/2017, Make MSI Gaming X, danoliver1, Link
Date 14/04/2017, Make Gigabyte Gaming OC, shrek2, Link
Date 12/04/2017, Make Asus Founders Edition, rIcK, Link
Date 12/04/2017, Make Asus Strix, Kaiserwoem, Link
Date 12/04/2017, Make Asus Strix, azazl187, Link
Date 11/04/2017, Make MSI Gaming X, ghutchison14078, Link
Date 07/04/2017, Make Gigabyte Aorus, janksteruk, Link
Date 07/04/2017, Make Gigabyte Aorus, straxusii, Link
Date 06/04/2017, Make Gigabyte Aorus, Az_GTi, Link
Date 05/04/2017, Make MSI Sea Hawk, macca125, Link
Date 05/04/2017, Make Gigabyte Aorus, RecklessAZN, Link
Date 05/04/2017, Make Zotac Founders Edition, thefogo, Link
Date 05/04/2017, Make Gigabyte Founders Edition, Huntyz, Link
Date 05/04/2017, Make Gigabyte Aorus, WHAT21A, Link
Date 05/04/2017, Make Gigabyte Aorus, Coolasmoo, Link
Date 05/04/2017, Make MSI Gaming X, Gregster, Link
Date 05/04/2017, Make Gigabyte Aorus, smogsy, Link
Date 04/04/2017, Make MSI Founders Edition, Boomstick777, Link
Date 02/04/2017, Make Zotac Founders Edition, r7slayer, Link
Date 29/03/2017, Make Gigabyte Founders Edition, BSpendlove, Link
Date 29/03/2017, Make EVGA Founders Edition, FlyingScotsman, Link
Date 29/03/2017, Make Asus Strix, Aylan1196, Link
Date 28/03/2017, Make Asus Founders Edition, Ace Modder, Link
Date 27/03/2017, Make EVGA Founders Edition, Kaapstad, Link
Date 27/03/2017, Make Gigabyte Founders Edition, Flying_Hellfish, Link
Date 25/03/2017, Make EVGA Founders Edition, [Death], Link
Date 23/03/2017, Make EVGA Founders Edition, mingey, Link
Date 22/03/2017, Make EVGA Founders Edition, Razor Time, Link
Date 21/03/2017, Make Zotac Founders Edition, Andy321, Link
Date 21/03/2017, Make Zotac Founders Edition, Radeon85, Link
Date 21/03/2017, Make Zotac Founders Edition, epc1, Link
Date 20/03/2017, Make Gigabyte Founders Edition, AstinGC90, Link
Date 19/03/2017, Make NVidia Founders Edition, BaDBoY_uK, Link
Date 19/03/2017, Make NVidia Founders Edition, ChrisD, Link
Date 18/03/2017, Make EVGA Founders Edition, Tommy_Here, Link
Date 18/03/2017, Make EVGA Founders Edition, ntemples1, Link
Date 17/03/2017, Make MSI Founders Edition, Rossi~, Link
Date 16/03/2017, Make Gigabyte Founders Edition, Ayahuasca, Link
Date 15/03/2017, Make Zotac Founders Edition, Sem, Link
Date 15/03/2017, Make Zotac Founders Edition, Gripen90, Link
Date 15/03/2017, Make Asus Founders Edition, ZeroG, Link
Date 15/03/2017, Make NVidia Founders Edition, atomic7431, Link
Date 15/03/2017, Make NVidia Founders Edition, Glanza, Link
Date 14/03/2017, Make MSI Founders Edition, Choimaloy75, Link
Date 14/03/2017, Make MSI Founders Edition, rtho782, Link
Date 13/03/2017, Make EVGA Founders Edition, Radox-0, Link
Date 12/03/2017, Make EVGA Founders Edition, Dicehunter, Link
Date 12/03/2017, Make NVidia Founders Edition, The Artfull Bodger, Link
Date 12/03/2017, Make EVGA Founders Edition, khemist, Link
Date 12/03/2017, Make EVGA Founders Edition, dnic77, Link
Date 11/03/2017, Make EVGA Founders Edition, trawetSluaP, Link
Date 11/03/2017, Make EVGA Founders Edition, Xereo, Link
Date 11/03/2017, Make EVGA Founders Edition, madindehead, Link
Date 11/03/2017, Make EVGA Founders Edition, Techen, Link
Date 11/03/2017, Make Asus Founders Edition, bemaniac, Link
Date 11/03/2017, Make EVGA Founders Edition, deFiniLoGy, Link
Date 11/03/2017, Make NVidia Founders Edition, roysters, Link
Date 11/03/2017, Make EVGA Founders Edition, Mean Mr Mustard, Link
Date 11/03/2017, Make Zotac Founders Edition, sk3lph, Link
Date 10/03/2017, Make NVidia Founders Edition, stooeh, Link
Date 10/03/2017, Make NVidia Founders Edition, IT Troll, Link
Date 10/03/2017, Make NVidia Founders Edition, RichardH754, Link
Date 10/03/2017, Make NVidia Founders Edition, RichL, Link
Date 10/03/2017, Make NVidia Founders Edition, traveyb, Link
Date 10/03/2017, Make NVidia Founders Edition, Amatyr, Link
Date 10/03/2017, Make NVidia Founders Edition, X-Mikuru_Beam-X, Link
Date 10/03/2017, Make NVidia Founders Edition, Robzere31, Link
Date 10/03/2017, Make NVidia Founders Edition, Speed, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080 Ti.
3 Jul 2014
LOL. Yeah you do and yes I do as well. 2nd 8 pin cable was in storage in the attic so I thought I'd get it when I put the ASUS Box in the attic. Wanted to get the picture in quickly though to get on TROH.
Was wondering if anyone would spot it :) all
Plugged in and working and OC to 2025 so far...
Man of Honour
21 Nov 2004
This thing is impressive. I love that the fans stay off when not in use (and even when in use it takes a while to get up to temperature). Too use to AMD cards cooking themselves.
1 Apr 2010
Your welcome mate, sorry to hear it couldn't help push you a bit further along.
