I can't even play the game. It loads the little splash screen then my PC crashes and restarts!
I would also check any overclock you have on anything. Game is quiet CPU intensive at that inital splash screen for some reason. Have found if my CPU was not fully stable as a result of an overclock it seemed to crash. Could be worthwhile trying to remove any OC on anything and seeing if that helps.
