AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
Caporegime
1 Dec 2010
Welling, London
Manual overclocking is almost dead when PBO/Boost/Whatever eeks out most of what you will get anyway without pushing crazy volts. Choice is basically do you go for highest all core clock or highest boost.
That’s exactly what I was thinking. If that’s the case, then it really doesn’t matter what their manual overclocking ability is like as you’re better off just letting the cpu do its thing anyway.
16 Jan 2010
Earth
I don't think anyone here expects them not to since we are the ones who benefit from competition. I just don't think it will go down very well for them to hype PBO so much if the CPUs don't have any OC potential, because its their reputation on the line. Considering its all eyes on Zen 2 at the moment, it can hurt their sales.
I don't see them having any additional overclocking potential beyond PBO, perhaps 50mhz. AMD seem to be selling GPUs and CPUs at 95% of their maximum performance straight out of the box these days. If it took LN2 and 1.77V to get a 3950 to 5.2Ghz then 4.6-4.7Ghz is the most were likely to see. I want to be wrong but I've been disappointed by AMD launches too many times to believe otherwise.
26 Sep 2017
In the Masonic Temple
Agreed apart from the Gpu's , the vega and Radeon 7 I overclocked substantially, the 7 from 1800 to 2200 core and 1000 to 1280 on the ram, thats a lot of percent, it was similar on the vega but not quite as massive.
Permabanned
15 Oct 2011
Nottingham Carlton
Manual overclocking is a waste of time. You drop your shiny new Ryzen into its socket and let the advanced algorithms do the work for you more efficiently.
Where is Fun in that ??
Btw new bioses
Version 5007
2019/07/01 10.16 MBytes
PRIME B350-PLUS BIOS 5007
Update new AGESA to improve compatibility;
Recommend updating the BIOS via EZ Flash.
https://www.asus.com/ch-de/Motherboa...HelpDesk_BIOS/
Version 5008
2019/07/01 9.97 MBytes
ROG STRIX B350-F GAMING BIOS 5008
https://www.asus.com/uk/Motherboards...HelpDesk_BIOS/
21 Jun 2018
Ashton
As long as it works as good as they make it sound, I prefer to use PBO. It really depends if its actually more efficient than manual OC.
15 Dec 2007
Also the Crosshair VII Hero is less than half the price of the Crosshair VIII Formula.
Obviously you'll get PCIE 4.0 but I really struggle to see that it's going to be significantly better.
