Nothing
If you're looking for low voltages under idle then I'm guessing this wont be the way to achieve that, but great for anything else.
I am not a fan of noisy pcs. Do I need a better cooler and if so which one do you reckon will be quiet and do the job without being disproportionate price wise to the chip.
the included cooler for the 3600 is at the performance level of the £15-20 aftermarket coolers.I am not a fan of noisy pcs. Do I need a better cooler and if so which one do you reckon will be quiet and do the job without being disproportionate price wise to the chip.
the best value cooler is the scythe mugen rev.b, but that's £43, whether you consider that disproportionate to a £190 chip?
oh. my bad. thought it was the spire that was included. not the stealth.Nah, the wraith stealth is far worse than even £15-£20 coolers.
in that case yeah, a £20ish cooler should fit the bill.
Doubt these have much headroom. Mine even runs hotter than I'd like. 75+ in IBT and 85+ in Prime 95.
). The only difference is that she's using a Wraith Prism (set to low) instead of the Wraith Stealth that comes with it and fixed custom fan settings that I came up with so it's essentially silent even when gaming.I was looking at the 3600, but with its popularity the price has gone up (which isn't a surprise). This has meant that currently there is only roughly a £20 difference between it and the 3600x, so I will probably go for that. I'm hoping it will go in my X370 board ok and help with performance in VR. I currently have a 1600 paired with a gtx1070, which I would like to upgrade to the 1070 super in a couple of months time.
