I didn't notice because they're very close to the top in the middle so are usually part of a dark task bar.What would you do?
Afternoon all,
Ordered mine from Overclockers yesterday and just had the despatch email. I have been reading this board for a while but is given I hopeful there is now more QC what should I be looking for when it arrives to make sure I have not got a refurb?
thanks
Josh
On a proper inspection it turns out my G95 has 3 dead pixels in a diagonal lineI didn't notice because they're very close to the top in the middle so are usually part of a dark task bar.
So I could live with them, but there's a concern that a cluster like this might grow, it's easier to return now as within returns period, and I paid a lot of money for a premium product I won't be replacing for many years so it ought to be perfect.
I appreciate that some say dead pixels are commonplace and a replacement might have them too but I haven't noticed many reports of them on this thread.
What would you do?
HiI got mine from OC, N5 and its perfect! No noise, no bad pixel.. Couldn't be happier! I would give them a call though, as when I called they said they had 65 back orders and thusly this batch was all sold out.
It's ridiculous that customer have to go through such stressful process of checking for faults after spending so money on a product.Personally, I would return. For this amount of money you should demand a monitor with no issues. I got 5 CRG49s, each had an issue that made me send it back.
. I have done a stuck / dead pixel check and it looks fine. But here are my current problemsThanks all.
Looks like I've got to phone up to do the replacement, probably because I bought from the EPP discount store. But I can't get hold of their dead pixel policy to quote at them. I know it's 1 per million but the ISO standard is stricter if they are in a cluster, which mine are.
I don't want to return/refund, I want to get in the queue for a replacement.
Are there still ongoing issues with the monitor though? There seems to be a lot of complaints around for what I imagine is a very niche product, bit surprising really!
Ok
I seemed to have fixed it. Had to connect hdmi and then add the DP and it showed up as a new screen with the right resolution.
i had no flicker at all until the last 2 geforce graphics drivers so i dialled back to a graphics driver before that and the flicker has now gone im using 452.06 with firmware 1006.2 on the g9
but the gsync flicker is annoying, subtle but irritating. I'm assuming its not a hardware fault as the gsync implementation is software
