Deleted User 298457
Deleted User 298457
OP
Yeah tyvek stuff is well regarded. If you want to go OTT you can get their full suite and tape any window openings etc...
Yeah the door itself is pretty low, I guess it's obvious when you think about it, but it's sitting on the beam and the 22mm chipboard, plus whatever ground you had to clear with the rods. So to "floor" level it's like 8 inches I guess! The internal threshold is like 25mm or maybe? I'll take a pic as I'm working from memory.Looks good. Is it a low threshold door? What's the gap to the bottom of the frame? I'm gonna probably put some decking infront of mine also. Bought loads of spare 3x4 due to minimum quantities and a couple extra rods.
Did you order doors before finishing the studwork etc?
I know - jammy bloke. I have an allotment about 10 meters from that which is pure straw. I might ask him for a swap plus cashsome decent looking onions there
I know - jammy bloke. I have an allotment about 10 meters from that which is pure straw. I might ask him for a swap plus cash![]()
Yep - super lucky to back onto allotments (the high snobiety type). The gate is onto the allotments. The plan was my girl would go to the school just through; but annoyingly we preferred the school up the busy roadIs that an actual allotment in the image or just a neighbour's garden? Also, is that a gate from your garden into it (just behind the water but thing)
Yeah exactly that- I probably paid over the odds but got it all from Rubber4roofs. It is exactly that, and that diagram is perfect to describe the slate batten approach. Makes a big difference. Guttering will be brilliant.pet/peter rabbit could have fun.
you glued the membrane across the full roof surface - spent some time gluing down roofing felt yesterday glue was horribly runny
guess the roof edge is like this ? https://ukflatroofing.com/classicbond-trims/sure-edge-gutter-drip-trim-anthracite-grey
No point on the floor as you'll have a vapour barrier/silver tape down (you'll be D4ing it to tape). For the roof, I glued the OSB3 to joists.Did you use D4 glue to the joists when putting your floor down, or for the roof OSB? I've seen videos of 30min glue and bought some but figure it's good to put to joists to stop creaking?
Ah that makes sense. Presume you just used the 30min glue to for the roof to tie it to the rafters?No point on the floor as you'll have a vapour barrier/silver tape down (you'll be D4ing it to tape). For the roof, I glued the OSB3 to joists.
I'm in deep trouble if those don't work as I am probably ~£200 in -
I use them every instance I take up floorboards. Touch wood, not a single creak...yet...![]()
SPAX Wirox T-STAR Plus Flooring Screw
Speed up your fastening jobs with these SPAX flooring screws. The screw head is specially designed for use with T-STAR Plus bits for a more secure fit - this means quicker, firmer and more efficient driving with no annoying bit slips.Flush screw insertion is easy with a countersunk head, and...www.toolstation.com
I believe you need to go inside and show us the dry space to prove that
I've lost the keysI believe you need to go inside and show us the dry space to prove that![]()
Yeah I think there a bunch of folk that have a mental barrier on the PIR. It isn't that bad at all TBH, especially if you use a nice long panel saw.Remind me why it's 50mm into walls and 100mm into roof again? Is it to allow space for electrical back boxes? Surprised people haven't gone for 75mm etc.
For me cutting the 100mm insulation didn't seem all that terrible just with a handsaw.
