yup, I'm quite loyal and normally stick to ocuk, but a hundred quid is a hundred quidDid you get them yesterday from "that" competitor shop for £1.299 each?
Cause I was so close to cancel my Duke preorder and get one as well.
Mines coming today woohoo !!! Can't wait my poor old Titan X (maxwell) I'll have to find a new home for it, it has been a good servant for sure.
I have two Titan X (maxwell) GPU's,
I used to have two, my son has one running a 1080p 144Hz monitor (christmas Present ) last yearAs have I. One will go in my backup system, the other will likely end up being a Christmas present.
Mine arrived yesterday, got a nice solid gaming O/C @ 1805mhz, boosts well into 2g most of the time. Max temp with this O/C with a 1:1 profile is 68C (power limit and volts also increased).
Those of you with 4K monitors + 2080Ti, assuming no G-Sync, how are you finding the experience? Are you locking off FPS at 59 to avoid issues, or does V-Sync handle things? Curious how this works.
Locking at 59 FPS doesn't eliminate issues with disabling V-sync. You can still see tearing and motion feels, well, desynchronized.
You either use V-sync and then you have maintain perfectly stable 60 FPS to avoid stuttering, or you use G-sync which feels like playing without V-sync but without its downsides, meaning less lag and FPS drops are much less visible, plus the motion is perfectly synchronized and generally everything is butter.
Objectively these are the only two quality options, anything else is a mess and you will need to have some specific characteristics to be able to accept it, for example you have to be unable to see tearing. Which is more than possible, looking at all the people saying things far more unlikely, like "smooth 30 FPS", "pin sharp 1080p" or "you don't need AA at 1440p and 4K"....
Mocking aside, after all it comes down to your specific case and this is the only thing you should care about. It is best to try all the options yourself and see what suits you.
I have flashed the bios of my Sea Hawk with 380W Galax one.
Power limit is still hit hard in benchmarks like Time Spy, but in games throttling point was moved significantly higher and now I am maintaining stable 2130-2145 MHz at 1.056V after reaching stable temperature (47C at 100% fan speed). On 330W I was throttling down to 2055-2070 MHz and had to keep voltage considerably below 1.000V to even achieve that.
So is G-Sync the only cure to eliminate all tearing/stuttering (as good as it will get anyway)? If you don't have G-Sync on a 4K monitor with a 2080/2080Ti (or any GPU I guess), are you just resigned to a certain amount of tearing/stutter in certain games, no matter what you do? I'm aware in some games this isn't going to be a problem.
If you have reasonable framerate overhead (which is questionable at 4K) then FastSync is an option. Otherwise the only mitigation really is adaptive V-Sync (not to be confused with Adapative Sync).
But if you're able top sustain >60 FPS at all times, then you're good... but even with a 2080Ti this isn't guaranteed in EVERY game.
Generally you're running a high ppi monitor so you really don't need AA at 4K. But my 2080 Ti is running my games at > 60 fps anyway.
How loud is the fan on the Sea Hawk? Especially at 100%?
47C doesn’t sound hot at all for an AIO.
