Fidelity Super Resolution 2.0
OP
25 Nov 2011
The KOP
I worded that incorrectly, I meant do you think we could see something like RSR2 that has the same benefits of FSR2 considering as you said FSR and RSR are basically the same ?
Basically the same in terms of the idea of what both try to achieve.
The method of the both is different though and it's why FSR 2.0 won't be able to make it driver side due to how it must hook into thr games rendering path.
FSR 1.0 is a simple method that can be done after the rendering path downside is full screen is changed and it doesn't get rid of the TAA artifacts like blurring etc
19 Feb 2007
ArcCorp
Ahh ok makes sense, Thanks for the info :)
Caporegime
4 Jun 2009
DLSS should be showing less shimmer and aliasing compared to native in cp2077. Gamers nexus etc. all noted this along with better temporal stability and that was with older versions too. Make sure you have CA, motion blur etc. effects turned off. If you aren't impressed with dlss in it then chances are you defo won't be with fsr 2 either.
Seems FSR 2 has some bad ghosting in FS, almost dlss v1.0/2.0 levels of bad:
