The Pascal GTX 1080 Ti Owners Thread
Very dissapointed by the zotac after this review, i've been on the fence about buying this card for ages, i'd go ftw3 now or strix
I've never seen the FTW3 go above 65 unless I uncap the framerate which would bring it up to 72 - 75c. Even the fans only hit 1030rpm. The CPU Phobya 120mm fan is the loudest thing in the case at 1500rpm. Saying that, I only have 4 fans running very low in the case. One 120mm for the hard drive/psu area. About 800rpm, max is 1800rpm? Two 140 roof fans at 420rpm and one rear 120mm fan at 750rpm, cannot hear it even at its max 1000rpm.
The card idles 0rpm between 27 - 29c.
The PC is still quieter than a PS4 Pro. Probably in line with my PS4 1200 chassis. Can barely hear it in quiet rooms.
It is great this in this time to be able to game and fans don't dominate a room. I remember pausing games, taking the headphones off and wondering, wait... this is odd, its so quiet. Quiet gaming and headphones = heaven.
@Gregster will love this:
Those temperatures. :eek:
Cool YT channel, I love his monitor, the temp drops is amazing 10-15%, watching him do it on a ftw3 card now, thanks :D
My Gaming X fans go absolutely bonkers more often than not. Firewatch and Overwatch being two of the least expected.
That was why he said to check the materials first before applying it.
Even at that, i'm not entirely sure how that stuff spreads when the heatsink is pressed down onto it, even a bit of overflow could cause something to short. You can repaste your gpu with regular tim, do it tidily and when you check later its usually spread out a little, presumably that stuff doesn't do that or only does minimally?
Best way is to tape it off really so only the die is exposed. Any overspill will not short it to the caps next to the die then.
But usually you use a very thin layer and spread it out manually.
Sort of tape would you use as it gets pretty hot round there, wouldn't it just peel off?
Or do you fit, remove, remove tape and refit? Is there no worry about trapped air with liquid metal?
Kapton or similar. Not really needed as it doesn't really spill or spread when done right. However it's another level of protection.
Not really a fan of liquid metal as it can give more problems that's not really worth it for a few degrees over the next best paste.
Funny how times have changed as I once remember Arctic Silver was the most hated paste here many years ago. Yet it is gooey unlike that liquid metal.
Though, the last I read from last year and going back further, IC Diamond got a lot of stick. Apparently it was very abrasive trying to remove it.
Never heard of that before but after a google looks like useful stuff, have to get some to keep in the shed I think.
Are the Ti's around the same performance as each other like the 1070's and 1080's? Just different coolers really?
Yeah but that can have a big effect on frame rates too. More cooling means less throttling. FE cards need aggressive fan profiles to keep its clock speeds steady for example. If a card runs cool it can maintain its performance over longer periods of time with higher boost clock speeds, and has more headroom for overclocking.
Some cards come overclocked out of the box and the price sometimes reflects that, but people mostly buy them for the effective coolers they use. Anybody can overclock a card.
Thinking about selling off my 1070 FTW2 and going for a Evga SC Black 1080ti.
Add me to the list.
Asus ROG Strix OC:
Managed to get the core to 2012 while gaming and +300 on the memory so far after playing for 5 minutes. Card is an absolute beast!
Josh.
Add me to the list.
Asus ROG Strix OC:
Josh.
Welcome and on TROH.:)
The Roll of Honour.
Date 10/07/2017, Make Asus Strix, JoshR1989, Link
Date 09/07/2017, Make Zotac Amp Edition, Azer, Link
Date 06/07/2017, Make Palit Super JetStream, khemist, Link
Date 05/07/2017, Make Palit Super JetStream, Confused Stu, Link
Date 05/07/2017, Make Inno3D Twin X2, Phixsator, Link
Date 03/07/2017, Make Gigabyte Aorus Xtreme, Puppetmaster, Link
Date 28/06/2017, Make EVGA FTW3 ICX, Wrinkly, Link
Date 24/06/2017, Make Zotac Amp Extreme, tyler_jrb, Link
Date 23/06/2017, Make Gigabyte Aorus Xtreme, Spikey, Link
Date 17/06/2017, Make Asus Strix, Ste, Link
Date 15/06/2017, Make Zotac Amp Extreme, C6ckneyGeezer, Link
Date 08/06/2017, Make KFA2 EXOC, ianh, Link
Date 08/06/2017, Make EVGA Founders Edition, rtho782, Link
Date 02/06/2017, Make MSI Gaming X, CEUOTC, Link
Date 01/06/2017, Make EVGA SC2 ICX, Roguey000, Link
Date 01/06/2017, Make EVGA FTW3 ICX, Jimmy G, Link
Date 27/05/2017, Make Asus Strix, Silent_Scone, Link
Date 27/05/2017, Make EVGA FTW3 ICX, GTA767, Link
Date 18/05/2017, Make MSI Gaming X, thefogo, Link
Date 15/05/2017, Make EVGA FTW3 ICX, jjwf, Link
Date 12/05/2017, Make Asus Strix, Clairvoyant, Link
Date 12/05/2017, Make Asus Founders Edition, Phemo, Link
Date 12/05/2017, Make EVGA FTW3 ICX, magicoi, Link
Date 11/05/2017, Make Inno3D Founders Edition, KNiVES, Link
Date 10/05/2017, Make MSI Gaming X, titaniumx3, Link
Date 09/05/2017, Make MSI Sea Hawk, Skyballer, Link
Date 09/05/2017, Make EVGA Founders Edition, String, Link
Date 07/05/2017, Make Zotac Amp Extreme, OG Don Mecca, Link
Date 07/05/2017, Make Palit GameRock, roddypoddy, Link
Date 06/05/2017, Make Asus Strix, spot35, Link
Date 06/05/2017, Make Zotac Amp Extreme, kayomani, Link
Date 06/05/2017, Make Zotac Amp Extreme, CaptainRAVE, Link
Date 04/05/2017, Make Gigabyte Aorus, zola25, Link
Date 04/05/2017, Make Asus Strix, Joe_Easy, Link
Date 03/05/2017, Make Palit Super JetStream, Telecaster, Link
Date 03/05/2017, Make Asus Strix, Monkeh, Link
Date 03/05/2017, Make Inno3D Founders Edition, offmyed, Link
Date 01/05/2017, Make Asus Strix, HaloUK, Link
Date 30/04/2017, Make Asus Strix, liammorris1990, Link
Date 29/04/2017, Make Asus Strix, N0ddie, Link
Date 29/04/2017, Make KFA2 Founders Edition, SupraWez, Link
Date 26/04/2017, Make Zotac Amp Extreme, EPCCare, Link
Date 25/04/2017, Make Zotac Amp Extreme, Kiro-San, Link
Date 23/04/2017, Make Zotac Amp Edition, TomDD, Link
Date 22/04/2017, Make EVGA Founders Edition, .:SAmSuNG:., Link
Date 22/04/2017, Make Gigabyte Gaming OC, digitalx, Link
Date 22/04/2017, Make MSI Gaming X, Atli, Link
Date 20/04/2017, Make Asus Strix, Mayh3M, Link
Date 20/04/2017, Make Zotac Amp Extreme, SupernovaUK, Link
Date 20/04/2017, Make Asus Strix, ThereIs0nly0ne, Link
Date 20/04/2017, Make Asus Strix, wingnutta, Link
Date 19/04/2017, Make MSI Sea Hawk, WhiteHawk77, Link
Date 19/04/2017, Make Zotac Amp Edition, Bindlestiff, Link
Date 19/04/2017, Make Gigabyte Aorus, LHM, Link
Date 15/04/2017, Make MSI Gaming X, danoliver1, Link
Date 14/04/2017, Make Gigabyte Gaming OC, shrek2, Link
Date 12/04/2017, Make Asus Founders Edition, rIcK, Link
Date 12/04/2017, Make Asus Strix, Kaiserwoem, Link
Date 12/04/2017, Make Asus Strix, azazl187, Link
Date 11/04/2017, Make MSI Gaming X, ghutchison14078, Link
Date 07/04/2017, Make Gigabyte Aorus, janksteruk, Link
Date 07/04/2017, Make Gigabyte Aorus, straxusii, Link
Date 06/04/2017, Make Gigabyte Aorus, Az_GTi, Link
Date 05/04/2017, Make MSI Sea Hawk, macca125, Link
Date 05/04/2017, Make Gigabyte Aorus, RecklessAZN, Link
Date 05/04/2017, Make Zotac Founders Edition, thefogo, Link
Date 05/04/2017, Make Gigabyte Founders Edition, Huntyz, Link
Date 05/04/2017, Make Gigabyte Aorus, WHAT21A, Link
Date 05/04/2017, Make Gigabyte Aorus, Coolasmoo, Link
Date 05/04/2017, Make MSI Gaming X, Gregster, Link
Date 05/04/2017, Make Gigabyte Aorus, smogsy, Link
Date 04/04/2017, Make MSI Founders Edition, Boomstick777, Link
Date 02/04/2017, Make Zotac Founders Edition, r7slayer, Link
Date 29/03/2017, Make Gigabyte Founders Edition, BSpendlove, Link
Date 29/03/2017, Make EVGA Founders Edition, FlyingScotsman, Link
Date 29/03/2017, Make Asus Strix, Aylan1196, Link
Date 28/03/2017, Make Asus Founders Edition, Ace Modder, Link
Date 27/03/2017, Make EVGA Founders Edition, Kaapstad, Link
Date 27/03/2017, Make Gigabyte Founders Edition, Flying_Hellfish, Link
Date 25/03/2017, Make EVGA Founders Edition, [Death], Link
Date 23/03/2017, Make EVGA Founders Edition, mingey, Link
Date 22/03/2017, Make EVGA Founders Edition, Razor Time, Link
Date 21/03/2017, Make Zotac Founders Edition, Andy321, Link
Date 21/03/2017, Make Zotac Founders Edition, Radeon85, Link
Date 21/03/2017, Make Zotac Founders Edition, epc1, Link
Date 20/03/2017, Make Gigabyte Founders Edition, AstinGC90, Link
Date 19/03/2017, Make NVidia Founders Edition, BaDBoY_uK, Link
Date 19/03/2017, Make NVidia Founders Edition, ChrisD, Link
Date 18/03/2017, Make EVGA Founders Edition, Tommy_Here, Link
Date 18/03/2017, Make EVGA Founders Edition, ntemples1, Link
Date 17/03/2017, Make MSI Founders Edition, Rossi~, Link
Date 16/03/2017, Make Gigabyte Founders Edition, Ayahuasca, Link
Date 15/03/2017, Make Zotac Founders Edition, Sem, Link
Date 15/03/2017, Make Zotac Founders Edition, Gripen90, Link
Date 15/03/2017, Make Asus Founders Edition, ZeroG, Link
Date 15/03/2017, Make NVidia Founders Edition, atomic7431, Link
Date 15/03/2017, Make NVidia Founders Edition, Glanza, Link
Date 14/03/2017, Make MSI Founders Edition, Choimaloy75, Link
Date 14/03/2017, Make MSI Founders Edition, rtho782, Link
Date 13/03/2017, Make EVGA Founders Edition, Radox-0, Link
Date 12/03/2017, Make EVGA Founders Edition, Dicehunter, Link
Date 12/03/2017, Make NVidia Founders Edition, The Artfull Bodger, Link
Date 12/03/2017, Make EVGA Founders Edition, khemist, Link
Date 12/03/2017, Make EVGA Founders Edition, dnic77, Link
Date 11/03/2017, Make EVGA Founders Edition, trawetSluaP, Link
Date 11/03/2017, Make EVGA Founders Edition, Xereo, Link
Date 11/03/2017, Make EVGA Founders Edition, madindehead, Link
Date 11/03/2017, Make EVGA Founders Edition, Techen, Link
Date 11/03/2017, Make Asus Founders Edition, bemaniac, Link
Date 11/03/2017, Make EVGA Founders Edition, deFiniLoGy, Link
Date 11/03/2017, Make NVidia Founders Edition, roysters, Link
Date 11/03/2017, Make EVGA Founders Edition, Mean Mr Mustard, Link
Date 11/03/2017, Make Zotac Founders Edition, sk3lph, Link
Date 10/03/2017, Make NVidia Founders Edition, stooeh, Link
Date 10/03/2017, Make NVidia Founders Edition, IT Troll, Link
Date 10/03/2017, Make NVidia Founders Edition, RichardH754, Link
Date 10/03/2017, Make NVidia Founders Edition, RichL, Link
Date 10/03/2017, Make NVidia Founders Edition, traveyb, Link
Date 10/03/2017, Make NVidia Founders Edition, Amatyr, Link
Date 10/03/2017, Make NVidia Founders Edition, X-Mikuru_Beam-X, Link
Date 10/03/2017, Make NVidia Founders Edition, Robzere31, Link
Date 10/03/2017, Make NVidia Founders Edition, Speed, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080 Ti.
