The RX Vega 64 Owners Thread
If anyone is interested in Eiswolf performance, I've relived a quick vid to show temps and performance. It's a truly boring vid, but what would you expect!
Wattman settings are at the end.
Will get one taken and up tomorrow, as got to go out in a bit :( :p
Just been playing a bit of DOOM in Vulkan, on the Nightmare Texture Setting, and everything else maxed as well, was getting around 170/80fps :eek:, got the weird white line effect though, but a bit of googling found how to fix that, so will try that tomorrow as well :D
We believe you don't we @nashathedog :p
Yeah Yeah Loadsa, We've all heard that old chestnut.
ufacQ77
Hello,
New user of Vega64 Liquid edition. Proud owner after using 1080GTX.
Photos regarding hall of honour and radiator placement.
I placed the push pull in front of case . Z1 neo Zalman . For intake so the card remains always below 60 degrees with low noise and furthermore rysen [email protected] also with push pull does not exceed 65 degrees . Been seen this forum several days now and it is my everyday learning place :) .
Cheers from Greece ,
P.S. Here the prices are around 550-600 euros for reference Vega64 , 700 for Liquid
and 1080ti above 800 euros, as an example of pricing.
I've playing Wolfenstien II The New Colossus with my VEGA 64 and an Acer XR341CK over the display port, I've set VSYNC Off and the Frame Target Control to 75fps, frame rate is pretty constant but I'm seeing pretty bad screen tearing, the OSD on the monitor shows FREESYNC is enabled.
Anybody else seeing this?
Cheers Ginga I’ll give it a whirl, I’ve actually got a couple of hours to sit down and play games this afternoon, wonders never cease!
I've seen tearing in this game with Rivatuner limiting the FPS @144 to match the monitor's 144Hz (Freesync on). So I tried limiting to 143 FPS which either fixes it or improves it a lot. Frame rate control didn't hard limit the FPS so I don't use it.
ufacQ77
Hello,
Welcome and on TROH.:)
The Roll of Honour.
Date 24/11/2017, Make Reference AIO, jimpsar, Link
Date 21/11/2017, Make Reference AIO, LoadsaMoney, Link
Date 14/11/2017, Make Reference Air, pete910, Link
Date 09/11/2017, Make Reference Air, TrixX, Link
Date 08/11/2017, Make Reference Air, acraftygnome, Link
Date 08/11/2017, Make Reference Air, ree, Link
Date 04/11/2017, Make Reference AIO, HEADRAT, Link
Date 03/11/2017, Make Reference Air, nashathedog, Link
Date 21/10/2017, Make Reference Air, Martini1991, Link
Date 01/10/2017, Make Reference Air, sharmanov, Link
Date 29/09/2017, Make Reference Air, Dempsey22, Link
Date 13/09/2017, Make Reference Air, Dicehunter, Link
Date 12/09/2017, Make Reference AIO, Kaapstad, Link
Date 06/09/2017, Make Reference Air, naLor, Link
Date 06/09/2017, Make Reference AIO, tres_kun, Link
Date 06/09/2017, Make Reference AIO, Biffa, Link
Date 05/09/2017, Make Reference Air, Lustral, Link
Date 05/09/2017, Make Reference Air, Synchrouk, Link
Date 02/09/2017, Make Reference AIO, Tinek, Link
Date 02/09/2017, Make Reference Air, AmateurExpert, Link
Date 01/09/2017, Make Reference AIO, Nemesis.ie, Link
Date 31/08/2017, Make Reference Air, Boomstick777, Link
Date 31/08/2017, Make Reference Air, Paul Campbell, Link
Date 31/08/2017, Make Reference Air, shankly1985, Link
Date 30/08/2017, Make Reference AIO, Chewie, Link
Date 30/08/2017, Make Reference Air, Shiari, Link
Date 30/08/2017, Make Reference Air, chaosophy, Link
Date 29/08/2017, Make Reference AIO, BadIronTree, Link
Date 28/08/2017, Make Reference Air, Neutral, Link
Date 26/08/2017, Make Reference AIO, iihavetoes, Link
Date 25/08/2017, Make Reference Air, disi, Link
Date 25/08/2017, Make Reference AIO, djbully, Link
Date 24/08/2017, Make Reference Air, Bonjour, Link
Date 24/08/2017, Make Reference Air, Kmodo, Link
Date 23/08/2017, Make Reference AIO, Dave2150, Link
Date 23/08/2017, Make Reference Air, Roughneck, Link
Date 21/08/2017, Make Reference AIO, diziet, Link
Date 19/08/2017, Make Reference Air, CapitalOne, Link
Date 18/08/2017, Make Reference AIO, NathG79, Link
Date 18/08/2017, Make Reference Air, Chrisc, Link
Date 17/08/2017, Make Reference AIO, DazQ87, Link
Date 17/08/2017, Make Reference Air, Smudge, Link
Date 17/08/2017, Make Reference Air, ChosenName, Link
Date 17/08/2017, Make Reference Air, mattyc123, Link
Date 16/08/2017, Make Reference Air, WhistleBlower07, Link
Date 16/08/2017, Make Reference AIO, nashathedog, Link
Date 16/08/2017, Make Reference AIO, heartburnron, Link
Date 16/08/2017, Make Reference Air, vanpeebles, Link
Date 15/08/2017, Make Reference Air, Morve, Link
Date 15/08/2017, Make Reference Air, Howling, Link
Date 15/08/2017, Make Reference Air, Apache14, Link
Date 15/08/2017, Make Reference AIO, Dianbobo, Link
Date 15/08/2017, Make Reference Air, ubersonic, Link
Date 15/08/2017, Make Reference AIO, AMDMatt, Link
Date 15/08/2017, Make Reference Air, TonyTurbo78, Link
Date 15/08/2017, Make Reference AIO, MDPlatts, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Vega 64.
That's pretty much exactly the settings/temps i get also, good to know . The hotspot would be a little better if lower as the liquid cooled bios really pushes it.
