The Pascal GTX 1080 Ti Owners Thread
Man of Honour
OP
21 May 2012
Dalek flagship
Volta seems like it WILL be a monster. Biggest die ever and the most amount of transistors. New cores. Tensor? It's going to be a beast!
I don't think a lot of this will make it to the gaming cards.
It is a bit like comparing the GP100 and GP102 pascal cards using transistor count to see the difference in size (15.3B compared to 12B).:)
26 Aug 2004
South Wales
If Titan cards were given a bare minimum 6-8 months of being top end, i would potentially consider buying one but that's not always guaranteed, shame they don't release the Ti's at the same time but Nvidia knows that some will just buy the Titan instead of waiting.
Miss the days of the top end card coming first and staying there for some time, while not being priced over the top, ah well.
Man of Honour
OP
21 May 2012
Dalek flagship
The original Pascal Titan launched last year (August) and still beats the newer 1080 Ti in most things, the only card it can not beat is the newer Titan Xp.:)
Having said that the GTX 1080 Ti is far better value for money as a gaming card.
Caporegime
20 May 2007
Surrey
I am trying a replacement for my 1080Ti black as the fans seem to make some weird resonant howling noise at exactly 32% fan speed/1200rpm and 64% fan speed 2400rpm.
Posted on EVGA's forum and opinion was mixed on whether it was normal or not so I though I would at least try and see if a replacement card is any better.
This is the issue it has - exactly the same noise.
https://www.youtube.com/watch?v=1DP-GVKyMOs&feature=youtu.be
Need to turn it up loud but you can hear the noise at about ~18 seconds and then from ~50 seconds and then gets louder at about 1 min and 2 secs and again at 1 min 42 secs.
Granted it is only at one specific fan speed so i could just set a custom fan curve but I should be able to just have it run on auto without fiddling with this and it still makes the noise as it passes up and down through that rpm range.
Does anyone else have an EVGA card with this cooler that does this?
V F
V F
13 Aug 2003
UK
I found the OC mode to be a little conservative and way off the zotac. I added +65 to the core and +560 to the memory (can't get any more out of the core, memory might have some headroom). Stable in time spy stress tests, need to run a good few more. Custom fan curve (0% at 55 to 100% at 80) is keeping the card at 72Cish with an equal fan percentage. Boost keeps it 2025 at the very lowest, 2050 typically. Happy with that on air.
How is the fan sound?
30 Dec 2015
If I got another Strix OC for SLI would a Corsair AX760 be enough juice to OC everything and power a custom loop? CPU is a 4790k, only other items are SSD's and a sound card I plan to add.
I would buy a 1000w platinum or titanium PSU but finding one at a reasonable price at the minute isn't easy as we're all aware.
Josh.
6 Jan 2013
Rollergirl
Josh.
No. You've been considering a 1000w for a reason. The minimum you should be considering for sli is 850w.
V F
V F
13 Aug 2003
UK
Horrible branding Xp. I think back to Athlon XP, Detonator XP...
6 Jan 2013
Rollergirl
Think there's one in the states but the block is made by someone else now, evga will let you remove the cooler anyway so just buy a card and suitable block.
Josh.
Yes, I already did that mate. I'll put it in a spoiler, as the Vega bus might be driving past here and I don't like to taunt them too much:
I've just picked up a 980ti Hydro Copper for my son's rig, and was thinking I would have liked a 1080ti Hydro Copper but couldn't remember seeing one. I'll always water cool my cards, so it would have been easier all round to have bought a Hydro Copper version.
Does anyone know why EVGA stopped doing them?
30 Dec 2010
AG Switzerland
As soon as the AMD info was available I popped out of work and pick this up from a shop 10 mins down the road.
Really happy to join the club, can't wait to see the difference from my GTX-970, maybe I get a prize (or a kick in the goolies), for having the most embarrassing post-it notes!!
V F
V F
13 Aug 2003
UK
Nice single card slot. :)
Man of Honour
OP
21 May 2012
Dalek flagship
Really happy to join the club, can't wait to see the difference from my GTX-470, maybe I get a prize (or a kick in the goolies), for having the most embarrassing post-it notes!!
Welcome and on TROH.:)
The Roll of Honour.
Date 14/08/2017, Make MSI Armor, Dr_Watson, Link
Date 07/08/2017, Make Gigabyte Aorus Xtreme, Scrumpy_Jack, Link
Date 07/08/2017, Make Gigabyte Aorus Xtreme, CaptainRAVE, Link
Date 04/08/2017, Make Asus Strix, toon_mad, Link
Date 03/08/2017, Make EVGA FTW3 ICX, khemist, Link
Date 03/08/2017, Make Asus Strix, Dicehunter, Link
Date 02/08/2017, Make Asus Founders Edition, amigafan2003, Link
Date 01/08/2017, Make Asus Poseidon, khemist, Link
Date 29/07/2017, Make KFA2 HOF, Besty, Link
Date 27/07/2017, Make MSI Lightning, akoska07, Link
Date 22/07/2017, Make EVGA SC Gaming, Evian, Link
Date 21/07/2017, Make MSI Gaming X, arby1, Link
Date 21/07/2017, Make EVGA SC Gaming, Jono8, Link
Date 19/07/2017, Make EVGA SC2 Hybrid, GoogalyMoogaly, Link
Date 19/07/2017, Make EVGA FTW3 ICX, skyda_killer, Link
Date 16/07/2017, Make EVGA FTW3 ICX, Kieran, Link
Date 14/07/2017, Make EVGA SC2 Hybrid, SS-89, Link
Date 14/07/2017, Make EVGA FTW3 ICX, GeneralD, Link
Date 12/07/2017, Make MSI Sea Hawk EK, yoyo59, Link
Date 10/07/2017, Make Asus Strix, JoshR1989, Link
Date 09/07/2017, Make Zotac Amp Edition, Azer, Link
Date 06/07/2017, Make Palit Super JetStream, khemist, Link
Date 05/07/2017, Make Palit Super JetStream, Confused Stu, Link
Date 05/07/2017, Make Inno3D Twin X2, Phixsator, Link
Date 03/07/2017, Make Gigabyte Aorus Xtreme, Puppetmaster, Link
Date 28/06/2017, Make EVGA FTW3 ICX, Wrinkly, Link
Date 24/06/2017, Make Zotac Amp Extreme, tyler_jrb, Link
Date 23/06/2017, Make Gigabyte Aorus Xtreme, Spikey, Link
Date 17/06/2017, Make Asus Strix, Ste, Link
Date 15/06/2017, Make Zotac Amp Extreme, C6ckneyGeezer, Link
Date 08/06/2017, Make KFA2 EXOC, ianh, Link
Date 08/06/2017, Make EVGA Founders Edition, rtho782, Link
Date 02/06/2017, Make MSI Gaming X, CEUOTC, Link
Date 01/06/2017, Make EVGA SC2 ICX, Roguey000, Link
Date 01/06/2017, Make EVGA FTW3 ICX, Jimmy G, Link
Date 27/05/2017, Make Asus Strix, Silent_Scone, Link
Date 27/05/2017, Make EVGA FTW3 ICX, GTA767, Link
Date 18/05/2017, Make MSI Gaming X, thefogo, Link
Date 15/05/2017, Make EVGA FTW3 ICX, jjwf, Link
Date 12/05/2017, Make Asus Strix, Clairvoyant, Link
Date 12/05/2017, Make Asus Founders Edition, Phemo, Link
Date 12/05/2017, Make EVGA FTW3 ICX, magicoi, Link
Date 11/05/2017, Make Inno3D Founders Edition, KNiVES, Link
Date 10/05/2017, Make MSI Gaming X, titaniumx3, Link
Date 09/05/2017, Make MSI Sea Hawk, Skyballer, Link
Date 09/05/2017, Make EVGA Founders Edition, String, Link
Date 07/05/2017, Make Zotac Amp Extreme, OG Don Mecca, Link
Date 07/05/2017, Make Palit GameRock, roddypoddy, Link
Date 06/05/2017, Make Asus Strix, spot35, Link
Date 06/05/2017, Make Zotac Amp Extreme, kayomani, Link
Date 06/05/2017, Make Zotac Amp Extreme, CaptainRAVE, Link
Date 04/05/2017, Make Gigabyte Aorus, zola25, Link
Date 04/05/2017, Make Asus Strix, Joe_Easy, Link
Date 03/05/2017, Make Palit Super JetStream, Telecaster, Link
Date 03/05/2017, Make Asus Strix, Monkeh, Link
Date 03/05/2017, Make Inno3D Founders Edition, offmyed, Link
Date 01/05/2017, Make Asus Strix, HaloUK, Link
Date 30/04/2017, Make Asus Strix, liammorris1990, Link
Date 29/04/2017, Make Asus Strix, N0ddie, Link
Date 29/04/2017, Make KFA2 Founders Edition, SupraWez, Link
Date 26/04/2017, Make Zotac Amp Extreme, EPCCare, Link
Date 25/04/2017, Make Zotac Amp Extreme, Kiro-San, Link
Date 23/04/2017, Make Zotac Amp Edition, TomDD, Link
Date 22/04/2017, Make EVGA Founders Edition, .:SAmSuNG:., Link
Date 22/04/2017, Make Gigabyte Gaming OC, digitalx, Link
Date 22/04/2017, Make MSI Gaming X, Atli, Link
Date 20/04/2017, Make Asus Strix, Mayh3M, Link
Date 20/04/2017, Make Zotac Amp Extreme, SupernovaUK, Link
Date 20/04/2017, Make Asus Strix, ThereIs0nly0ne, Link
Date 20/04/2017, Make Asus Strix, wingnutta, Link
Date 19/04/2017, Make MSI Sea Hawk, WhiteHawk77, Link
Date 19/04/2017, Make Zotac Amp Edition, Bindlestiff, Link
Date 19/04/2017, Make Gigabyte Aorus, LHM, Link
Date 15/04/2017, Make MSI Gaming X, danoliver1, Link
Date 14/04/2017, Make Gigabyte Gaming OC, shrek2, Link
Date 12/04/2017, Make Asus Founders Edition, rIcK, Link
Date 12/04/2017, Make Asus Strix, Kaiserwoem, Link
Date 12/04/2017, Make Asus Strix, azazl187, Link
Date 11/04/2017, Make MSI Gaming X, ghutchison14078, Link
Date 07/04/2017, Make Gigabyte Aorus, janksteruk, Link
Date 07/04/2017, Make Gigabyte Aorus, straxusii, Link
Date 06/04/2017, Make Gigabyte Aorus, Az_GTi, Link
Date 05/04/2017, Make MSI Sea Hawk, macca125, Link
Date 05/04/2017, Make Gigabyte Aorus, RecklessAZN, Link
Date 05/04/2017, Make Zotac Founders Edition, thefogo, Link
Date 05/04/2017, Make Gigabyte Founders Edition, Huntyz, Link
Date 05/04/2017, Make Gigabyte Aorus, WHAT21A, Link
Date 05/04/2017, Make Gigabyte Aorus, Coolasmoo, Link
Date 05/04/2017, Make MSI Gaming X, Gregster, Link
Date 05/04/2017, Make Gigabyte Aorus, smogsy, Link
Date 04/04/2017, Make MSI Founders Edition, Boomstick777, Link
Date 02/04/2017, Make Zotac Founders Edition, r7slayer, Link
Date 29/03/2017, Make Gigabyte Founders Edition, BSpendlove, Link
Date 29/03/2017, Make EVGA Founders Edition, FlyingScotsman, Link
Date 29/03/2017, Make Asus Strix, Aylan1196, Link
Date 28/03/2017, Make Asus Founders Edition, Ace Modder, Link
Date 27/03/2017, Make EVGA Founders Edition, Kaapstad, Link
Date 27/03/2017, Make Gigabyte Founders Edition, Flying_Hellfish, Link
Date 25/03/2017, Make EVGA Founders Edition, [Death], Link
Date 23/03/2017, Make EVGA Founders Edition, mingey, Link
Date 22/03/2017, Make EVGA Founders Edition, Razor Time, Link
Date 21/03/2017, Make Zotac Founders Edition, Andy321, Link
Date 21/03/2017, Make Zotac Founders Edition, Radeon85, Link
Date 21/03/2017, Make Zotac Founders Edition, epc1, Link
Date 20/03/2017, Make Gigabyte Founders Edition, AstinGC90, Link
Date 19/03/2017, Make NVidia Founders Edition, BaDBoY_uK, Link
Date 19/03/2017, Make NVidia Founders Edition, ChrisD, Link
Date 18/03/2017, Make EVGA Founders Edition, Tommy_Here, Link
Date 18/03/2017, Make EVGA Founders Edition, ntemples1, Link
Date 17/03/2017, Make MSI Founders Edition, Rossi~, Link
Date 16/03/2017, Make Gigabyte Founders Edition, Ayahuasca, Link
Date 15/03/2017, Make Zotac Founders Edition, Sem, Link
Date 15/03/2017, Make Zotac Founders Edition, Gripen90, Link
Date 15/03/2017, Make Asus Founders Edition, ZeroG, Link
Date 15/03/2017, Make NVidia Founders Edition, atomic7431, Link
Date 15/03/2017, Make NVidia Founders Edition, Glanza, Link
Date 14/03/2017, Make MSI Founders Edition, Choimaloy75, Link
Date 14/03/2017, Make MSI Founders Edition, rtho782, Link
Date 13/03/2017, Make EVGA Founders Edition, Radox-0, Link
Date 12/03/2017, Make EVGA Founders Edition, Dicehunter, Link
Date 12/03/2017, Make NVidia Founders Edition, The Artfull Bodger, Link
Date 12/03/2017, Make EVGA Founders Edition, khemist, Link
Date 12/03/2017, Make EVGA Founders Edition, dnic77, Link
Date 11/03/2017, Make EVGA Founders Edition, trawetSluaP, Link
Date 11/03/2017, Make EVGA Founders Edition, Xereo, Link
Date 11/03/2017, Make EVGA Founders Edition, madindehead, Link
Date 11/03/2017, Make EVGA Founders Edition, Techen, Link
Date 11/03/2017, Make Asus Founders Edition, bemaniac, Link
Date 11/03/2017, Make EVGA Founders Edition, deFiniLoGy, Link
Date 11/03/2017, Make NVidia Founders Edition, roysters, Link
Date 11/03/2017, Make EVGA Founders Edition, Mean Mr Mustard, Link
Date 11/03/2017, Make Zotac Founders Edition, sk3lph, Link
Date 10/03/2017, Make NVidia Founders Edition, stooeh, Link
Date 10/03/2017, Make NVidia Founders Edition, IT Troll, Link
Date 10/03/2017, Make NVidia Founders Edition, RichardH754, Link
Date 10/03/2017, Make NVidia Founders Edition, RichL, Link
Date 10/03/2017, Make NVidia Founders Edition, traveyb, Link
Date 10/03/2017, Make NVidia Founders Edition, Amatyr, Link
Date 10/03/2017, Make NVidia Founders Edition, X-Mikuru_Beam-X, Link
Date 10/03/2017, Make NVidia Founders Edition, Robzere31, Link
Date 10/03/2017, Make NVidia Founders Edition, Speed, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080 Ti.
