The Pascal GTX 1080 Ti Owners Thread
Good bye AMD it was fun but damn the drivers and the terrible crossings support has broken my hairy camels back..
How is the support on sli ? Please tell me it is t as bad as crossfire..
Basically upgrading from two fury x’s running at 4K.
I see that the 1080ti’s can handle a lot of games at that res at med to high settings..
If you get a good clocking Ti or one under water 4k60 is reasonable in nearly everything I have tried with a Ti at 2.1 core 6Ghz RAM with the odd dip, some stuff like BF1 with a 150 res scale needs SLI to keep over 60, SLI is hit an miss, I thought crossfire was better for scaling in my old games ( I had 3x290s ) but it is fair to say that GPUs were not as powerful as 1080Ti so might be why they scaled better, one Ti is similar or better than 2x290s and my scaling could be held back by my Ryzen perhaps? Doubt it looking at where my results place me on the benchmark threads here.
Really you want the 1080Ti under water as in a big gaming session its clocks will drop to ~1.5Ghz. where as water keeps it at 2+Ghz also try and find a higher TDP one, mine throttles not due to heat or voltage now its on water but due TDP.
Have you tried to flash bios,to get extra 30W of power? Which model have you got?
I can get just under 2100mhz Core (only just got the card) without any volts and same with max volts so IMO its the exact same as with my 780Ti then Titan XM in that they hit the Power Limit easily once you overclock and the stock Bios is to blame.
I had to use a custom Bios on both to get past this but for now the only option is to flash to another cards bios that has higher power limit.
Which bios have you used?I've got zotac gtx 1080ti FE underwater and I'm planning to flash it.ta
Not yet, I want to.
I have two different cards, 1 Nvidia FE and 1 Evga Gaming, the Nvidia one was the best on air, doing 2.1/6Ghz stock volts, once on water the EVGA seems to have come into its own, I guess it might have a higher TDP as it requires more volts match the clocks of the FE, but hits the power limit 90% less than the others, so I need to look into BIOS mods.
The EVGA one seems to run 6 DegC cooler, so might just be a better fit on the heat sink, I will refit the FE cooler at some point to test, as the Evga card takes its water from same loop and after the FE one.
I've got a pair of zotac fe. Both flashed with asusstrixxoc bios. No power limit. Both under water and temp never above 45deg even after continual bench runs at 1.2v.
The best results I get is 2088/12000 mhz.
In some scenario card is power limited.
I flashed card with xoc bios but my card didn't work properly.It didn't output picture at all trough DP (both outputs).
Flash was successful.I had cable connected trough gtx 1070 second card in the system,and this way card worked in games.
I backed up my bios with gpu-z but it seems it's corrupted,cos nvflash can't read it.
I flashed it back with bios from techpowerup zotac fe 86.02.39.00.01 and it works now.
Doug2507 which bios have you got backed up? I'm looking for 86.02.39.00.2E not on the website, unfortunately.
My card:
Zotac GeForce GTX 1080 Ti Blower
Bit late to the party but here is my FE 1080Ti from Nvidia Direct.
Looking forward to having a play tonight
Welcome and on TROH.:)
The Roll of Honour.
Date 02/11/2017, Make NVidia Founders Edition, Lustral, Link
Date 24/10/2017, Make EVGA Founders Edition, w1ze1, Link
Date 24/10/2017, Make Asus Strix, Mickcas, Link
Date 19/10/2017, Make Gigabyte Waterforce Xtreme, Gameruk, Link
Date 14/10/2017, Make Asus Poseidon, Blueglue, Link
Date 01/10/2017, Make EVGA FTW3 ICX, meh?, Link
Date 29/09/2017, Make EVGA FTW3 ICX, erazor51, Link
Date 25/09/2017, Make EVGA FTW3 ICX, anihcniedam, Link
Date 09/09/2017, Make EVGA Hydro Copper, JSW, Link
Date 02/09/2017, Make Gigabyte Gaming OC, lokiguesty, Link
Date 31/08/2017, Make NVidia Founders Edition, Joe_Easy, Link
Date 31/08/2017, Make EVGA FTW3 ICX, robin66, Link
Date 28/08/2017, Make Gigabyte Aorus Xtreme, Toadem, Link
Date 25/08/2017, Make Gigabyte Waterforce Xtreme, Loz, Link
Date 24/08/2017, Make Gigabyte Aorus Xtreme, Minusorange, Link
Date 23/08/2017, Make Gigabyte Aorus, Orcvader, Link
Date 22/08/2017, Make Asus Strix, IainR, Link
Date 22/08/2017, Make EVGA FTW3 ICX, RSR, Link
Date 22/08/2017, Make Palit Super JetStream, Richeh, Link
Date 21/08/2017, Make Asus Strix, pigeonguyuk, Link
Date 19/08/2017, Make Gigabyte Aorus Xtreme, Vargas, Link
Date 19/08/2017, Make MSI Lightning, Darren777, Link
Date 19/08/2017, Make Gigabyte Aorus Xtreme, Panos, Link
Date 18/08/2017, Make Gigabyte Aorus, dan958, Link
Date 18/08/2017, Make EVGA FTW3 ICX, Saftlad, Link
Date 17/08/2017, Make MSI Gaming X, Davanius, Link
Date 17/08/2017, Make KFA2 EXOC, queeg, Link
Date 14/08/2017, Make EVGA Founders Edition, HAz, Link
Date 14/08/2017, Make MSI Armor, Dr_Watson, Link
Date 07/08/2017, Make Gigabyte Aorus Xtreme, Scrumpy_Jack, Link
Date 07/08/2017, Make Gigabyte Aorus Xtreme, CaptainRAVE, Link
Date 04/08/2017, Make Asus Strix, toon_mad, Link
Date 03/08/2017, Make EVGA FTW3 ICX, khemist, Link
Date 03/08/2017, Make Asus Strix, Dicehunter, Link
Date 02/08/2017, Make Asus Founders Edition, amigafan2003, Link
Date 01/08/2017, Make Asus Poseidon, khemist, Link
Date 29/07/2017, Make KFA2 HOF, Besty, Link
Date 27/07/2017, Make MSI Lightning, akoska07, Link
Date 22/07/2017, Make EVGA SC Gaming, Evian, Link
Date 21/07/2017, Make MSI Gaming X, arby1, Link
Date 21/07/2017, Make EVGA SC Gaming, Jono8, Link
Date 19/07/2017, Make EVGA SC2 Hybrid, GoogalyMoogaly, Link
Date 19/07/2017, Make EVGA FTW3 ICX, skyda_killer, Link
Date 16/07/2017, Make EVGA FTW3 ICX, Kieran, Link
Date 14/07/2017, Make EVGA SC2 Hybrid, SS-89, Link
Date 14/07/2017, Make EVGA FTW3 ICX, GeneralD, Link
Date 12/07/2017, Make MSI Sea Hawk EK, yoyo59, Link
Date 10/07/2017, Make Asus Strix, JoshR1989, Link
Date 09/07/2017, Make Zotac Amp Edition, Azer, Link
Date 06/07/2017, Make Palit Super JetStream, khemist, Link
Date 05/07/2017, Make Palit Super JetStream, Confused Stu, Link
Date 05/07/2017, Make Inno3D Twin X2, Phixsator, Link
Date 03/07/2017, Make Gigabyte Aorus Xtreme, Puppetmaster, Link
Date 28/06/2017, Make EVGA FTW3 ICX, Wrinkly, Link
Date 24/06/2017, Make Zotac Amp Extreme, tyler_jrb, Link
Date 23/06/2017, Make Gigabyte Aorus Xtreme, Spikey, Link
Date 17/06/2017, Make Asus Strix, Ste, Link
Date 15/06/2017, Make Zotac Amp Extreme, C6ckneyGeezer, Link
Date 08/06/2017, Make KFA2 EXOC, ianh, Link
Date 08/06/2017, Make EVGA Founders Edition, rtho782, Link
Date 02/06/2017, Make MSI Gaming X, CEUOTC, Link
Date 01/06/2017, Make EVGA SC2 ICX, Roguey000, Link
Date 01/06/2017, Make EVGA FTW3 ICX, Jimmy G, Link
Date 27/05/2017, Make Asus Strix, Silent_Scone, Link
Date 27/05/2017, Make EVGA FTW3 ICX, GTA767, Link
Date 18/05/2017, Make MSI Gaming X, thefogo, Link
Date 15/05/2017, Make EVGA FTW3 ICX, jjwf, Link
Date 12/05/2017, Make Asus Strix, Clairvoyant, Link
Date 12/05/2017, Make Asus Founders Edition, Phemo, Link
Date 12/05/2017, Make EVGA FTW3 ICX, magicoi, Link
Date 11/05/2017, Make Inno3D Founders Edition, KNiVES, Link
Date 10/05/2017, Make MSI Gaming X, titaniumx3, Link
Date 09/05/2017, Make MSI Sea Hawk, Skyballer, Link
Date 09/05/2017, Make EVGA Founders Edition, String, Link
Date 07/05/2017, Make Zotac Amp Extreme, OG Don Mecca, Link
Date 07/05/2017, Make Palit GameRock, roddypoddy, Link
Date 06/05/2017, Make Asus Strix, spot35, Link
Date 06/05/2017, Make Zotac Amp Extreme, kayomani, Link
Date 06/05/2017, Make Zotac Amp Extreme, CaptainRAVE, Link
Date 04/05/2017, Make Gigabyte Aorus, zola25, Link
Date 04/05/2017, Make Asus Strix, Joe_Easy, Link
Date 03/05/2017, Make Palit Super JetStream, Telecaster, Link
Date 03/05/2017, Make Asus Strix, Monkeh, Link
Date 03/05/2017, Make Inno3D Founders Edition, offmyed, Link
Date 01/05/2017, Make Asus Strix, HaloUK, Link
Date 30/04/2017, Make Asus Strix, liammorris1990, Link
Date 29/04/2017, Make Asus Strix, N0ddie, Link
Date 29/04/2017, Make KFA2 Founders Edition, SupraWez, Link
Date 26/04/2017, Make Zotac Amp Extreme, EPCCare, Link
Date 25/04/2017, Make Zotac Amp Extreme, Kiro-San, Link
Date 23/04/2017, Make Zotac Amp Edition, TomDD, Link
Date 22/04/2017, Make EVGA Founders Edition, .:SAmSuNG:., Link
Date 22/04/2017, Make Gigabyte Gaming OC, digitalx, Link
Date 22/04/2017, Make MSI Gaming X, Atli, Link
Date 20/04/2017, Make Asus Strix, Mayh3M, Link
Date 20/04/2017, Make Zotac Amp Extreme, SupernovaUK, Link
Date 20/04/2017, Make Asus Strix, ThereIs0nly0ne, Link
Date 20/04/2017, Make Asus Strix, wingnutta, Link
Date 19/04/2017, Make MSI Sea Hawk, WhiteHawk77, Link
Date 19/04/2017, Make Zotac Amp Edition, Bindlestiff, Link
Date 19/04/2017, Make Gigabyte Aorus, LHM, Link
Date 15/04/2017, Make MSI Gaming X, danoliver1, Link
Date 14/04/2017, Make Gigabyte Gaming OC, shrek2, Link
Date 12/04/2017, Make Asus Founders Edition, rIcK, Link
Date 12/04/2017, Make Asus Strix, Kaiserwoem, Link
Date 12/04/2017, Make Asus Strix, azazl187, Link
Date 11/04/2017, Make MSI Gaming X, ghutchison14078, Link
Date 07/04/2017, Make Gigabyte Aorus, janksteruk, Link
Date 07/04/2017, Make Gigabyte Aorus, straxusii, Link
Date 06/04/2017, Make Gigabyte Aorus, Az_GTi, Link
Date 05/04/2017, Make MSI Sea Hawk, macca125, Link
Date 05/04/2017, Make Gigabyte Aorus, RecklessAZN, Link
Date 05/04/2017, Make Zotac Founders Edition, thefogo, Link
Date 05/04/2017, Make Gigabyte Founders Edition, Huntyz, Link
Date 05/04/2017, Make Gigabyte Aorus, WHAT21A, Link
Date 05/04/2017, Make Gigabyte Aorus, Coolasmoo, Link
Date 05/04/2017, Make MSI Gaming X, Gregster, Link
Date 05/04/2017, Make Gigabyte Aorus, smogsy, Link
Date 04/04/2017, Make MSI Founders Edition, Boomstick777, Link
Date 02/04/2017, Make Zotac Founders Edition, r7slayer, Link
Date 29/03/2017, Make Gigabyte Founders Edition, BSpendlove, Link
Date 29/03/2017, Make EVGA Founders Edition, FlyingScotsman, Link
Date 29/03/2017, Make Asus Strix, Aylan1196, Link
Date 28/03/2017, Make Asus Founders Edition, Ace Modder, Link
Date 27/03/2017, Make EVGA Founders Edition, Kaapstad, Link
Date 27/03/2017, Make Gigabyte Founders Edition, Flying_Hellfish, Link
Date 25/03/2017, Make EVGA Founders Edition, [Death], Link
Date 23/03/2017, Make EVGA Founders Edition, mingey, Link
Date 22/03/2017, Make EVGA Founders Edition, Razor Time, Link
Date 21/03/2017, Make Zotac Founders Edition, Andy321, Link
Date 21/03/2017, Make Zotac Founders Edition, Radeon85, Link
Date 21/03/2017, Make Zotac Founders Edition, epc1, Link
Date 20/03/2017, Make Gigabyte Founders Edition, AstinGC90, Link
Date 19/03/2017, Make NVidia Founders Edition, BaDBoY_uK, Link
Date 19/03/2017, Make NVidia Founders Edition, ChrisD, Link
Date 18/03/2017, Make EVGA Founders Edition, Tommy_Here, Link
Date 18/03/2017, Make EVGA Founders Edition, ntemples1, Link
Date 17/03/2017, Make MSI Founders Edition, Rossi~, Link
Date 16/03/2017, Make Gigabyte Founders Edition, Ayahuasca, Link
Date 15/03/2017, Make Zotac Founders Edition, Sem, Link
Date 15/03/2017, Make Zotac Founders Edition, Gripen90, Link
Date 15/03/2017, Make Asus Founders Edition, ZeroG, Link
Date 15/03/2017, Make NVidia Founders Edition, atomic7431, Link
Date 15/03/2017, Make NVidia Founders Edition, Glanza, Link
Date 14/03/2017, Make MSI Founders Edition, Choimaloy75, Link
Date 14/03/2017, Make MSI Founders Edition, rtho782, Link
Date 13/03/2017, Make EVGA Founders Edition, Radox-0, Link
Date 12/03/2017, Make EVGA Founders Edition, Dicehunter, Link
Date 12/03/2017, Make NVidia Founders Edition, The Artfull Bodger, Link
Date 12/03/2017, Make EVGA Founders Edition, khemist, Link
Date 12/03/2017, Make EVGA Founders Edition, dnic77, Link
Date 11/03/2017, Make EVGA Founders Edition, trawetSluaP, Link
Date 11/03/2017, Make EVGA Founders Edition, Xereo, Link
Date 11/03/2017, Make EVGA Founders Edition, madindehead, Link
Date 11/03/2017, Make EVGA Founders Edition, Techen, Link
Date 11/03/2017, Make Asus Founders Edition, bemaniac, Link
Date 11/03/2017, Make EVGA Founders Edition, deFiniLoGy, Link
Date 11/03/2017, Make NVidia Founders Edition, roysters, Link
Date 11/03/2017, Make EVGA Founders Edition, Mean Mr Mustard, Link
Date 11/03/2017, Make Zotac Founders Edition, sk3lph, Link
Date 10/03/2017, Make NVidia Founders Edition, stooeh, Link
Date 10/03/2017, Make NVidia Founders Edition, IT Troll, Link
Date 10/03/2017, Make NVidia Founders Edition, RichardH754, Link
Date 10/03/2017, Make NVidia Founders Edition, RichL, Link
Date 10/03/2017, Make NVidia Founders Edition, traveyb, Link
Date 10/03/2017, Make NVidia Founders Edition, Amatyr, Link
Date 10/03/2017, Make NVidia Founders Edition, X-Mikuru_Beam-X, Link
Date 10/03/2017, Make NVidia Founders Edition, Robzere31, Link
Date 10/03/2017, Make NVidia Founders Edition, Speed, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080 Ti.
Gotta say, I love nVidia's packaging on their cards :cool:
Deffo well packaged .
Had a quick play and wow it is a step up from a normal 1080. On Destiny 2 it is quite a bit smoother with higher detail settings too.
Plus it isn’t much louder than the normal 1080
It packs a serious grunt too. I run Destiny 2 on high preset at 4K60 and I can still put the resolution scaling to 120% without framedrops. I know some people like to run on highest preset but I can't tell the difference and the smoothness from the higher resolution scaling is gorgeous.
Not got my Sig in the picture but this arrived from OCUK today.
Intersted to know how it stacks up against my current Maxwell Titan X's in SLI
The Roll of Honour.
Date 03/11/2017, Make Zotac Amp Extreme, dessimpson, Link
Well. Having a few issues with this card. Keeps crashing on CSGO. Graphics glitches etc. BSOD TDR errors (or something like that).
Only appears to be on CSGO and the only other game I play is Titanfall 2 and it's been fine.
The last time it crashed I restarted and it's now saying I have to re-install CSGO!!
Luckily I've still got my two Titan X's if I decided to RMA it.
I really don't want to but I might have to try a fresh install of Win10 :(
