- 19 Feb 2007
- Northampton
......ah so you didn't need to try and connect the card to the actual vertical slots in the case to run the monitor cable to, your photo shows that. Instead you managed to get the DP cable through the horizontal slot and plug it into the vertically mounted card. That would be why you can get away with a 17cm or so PCI-e cable, not needing to extend as long. Great that it still fitted to your top PCI-e slot on your board.
Is it easy enough, using the magnetic base, to fit the bracket etc to then fit the card on to..?
Does the card still show as 4x for connection and all is well and stable etc...?
The £52.59 seems to be for the black one
Thanks
No magnetic base but it is very easy to fit the entire thing. What I did was do a dry run, Put the bracket with the card already fitted and screwed onto it, Put the entire thing into the case to see if it needs to be slid forward or backward, Got it into the right position to give the DP cable enough room to slide through, Tighten the thumbscreen, Insert the PCI-E extension in to the mobo and then slid the bracket into position and screw theeverything down.
If you are really careful and take your time it's a 10 minute job and very easy, The card shows up in GPU-Z as PCI-E 4.0 x16 and everything is very stable, You only need to be careful with the PCI-E extension as all of them regardless of brand can be fragile so no sharp bends.
@Kaapstad
Video for the user video section. Alien Isolation running maxed out at 8K with the fairly taxing Alias Isolation TAA mod.
