- 31 Jul 2010
- Stoke-on-Trent
Go on then!
I'll resize images
I'll resize images
Arrived today. Xmas came early this year!
Indeed, where do we get this benchmark![]()
I've noticed a few people have the Gigabyte Gaming OC 2080ti and haven't been too impressed with the cooler, well I decided to whack a waterblock on mine and I'm now sitting at 2055mhz core and 7450mhz mem (and that is basically just running the OC scanner without any extra fiddling to fine tune), which is up about 90 on core and 150 on mem over what was stable in everything before.
http://benchmark.finalfantasyxv.com/na/
To get DLSS to run you need to select 2160p resolution and turn DLSS on in the custom settings.
Ooh pretty tight to the glass when its on, how are temps working out?
Hovering around mid 70's under full load so im going to keep an eye on it and maybe go back to the traditional way and see how that holds up.
Hi, what settings did you use under Custom (except the DLSS on)?Just ran this for another thread.
Just tried out DLSS on FFXV demo.
2080 Ti stock
7980XE @4.7
DLSS off
2080 Ti stock
7980XE @4.7
DLSS on
2080 Ti @2070/4000
7980XE @4.7
DLSS on
Impressive numbers using DLSS.![]()
High quality
2160p
Full screen
Then go into Custom and select DLSS.
OK
But this is not High Quality to me:
I tried to set everything on Highest / On (except AA), Dlss on and only got ~6350
