I think Gibbo mentioned they are due soon but don’t quote me on that.
7900 XT Nitro are with us next week.
Ive either read or seen on YouTube an review of it (hellhound xt), I think the verdict was its a decent enough cooler, probably better than MBA for cooling but feels cheap and plastic. You should be able to find the review tho.I'll keep searching.... I prefer the looks of the MBA to be honest and if temps aren't much better i might just get the MBA.
The dream would be a 7900xt Nitro+ and I could just about squeeze it into the budget but does anyone know when OcUK will be getting them?
used gpu-z : (GPU Temperature (hotspot) = 93 c , is that tjunction temps@anthony99 that might be due to another reasons. but what's the temperature the junction reached during the stress test?
Its for the XTX sadly.Ive either read or seen on YouTube an review of it (hellhound xt), I think the verdict was its a decent enough cooler, probably better than MBA for cooling but feels cheap and plastic. You should be able to find the review tho.
hwinfo64 is great, all sensors you need are in there..trying to find a program to show tjunction temps
Yes using hwinfo64 (gpu memory junction temp was hovering around 88) and the (gpu hot spot temp was about 95 max ) Thanks for your input hope you have a good outcome!hwinfo64 is great, all sensors you need are in there..
if after the FFE stress test your juction is just 93C, you should be fine. Mine was 115C in the second test, so, I'm returning it, sadly..
Yes you are right just found it.Its for the XTX sadly.
Very very tempting, should fit in my nr200p max........just.
Seemingly 366mmx160mm inc power adapter/cable x75mm is the absolute maximum that can be jammed in it.Out of interest does the Nitro+ XTX fit in the nr200p max as well?
As I’ve got the same case. I know a 4090FE fits in a treat which is a big lump.
I've had an order shipped email from ocuk, so fingers crossed arriving tomorrow.Phone up and ask when it'll be dispatched and it'll probably be today if you are in luck. If you leave it and wait, might be a few days based off mine and a few others here experiences.
I just received email confirmation that my MBA return has been refunded. It was with them about a day and a half before the confirmation came.My red devil xtx shipped earlier, still no word on a return for my MBA![]()
OcuK are generally pretty quick dealing with returns and refunds, never any complaints from me in that regard. Same can't always be said for some other UK retailers mind.I just received email confirmation that my MBA return has been refunded. It was with them about a day and a half before the confirmation came.
