The Turing RTX 2080 Ti Owners Thread
Sorry to hijack your quote, but interested in wgar you are at on the core clock to get that speed? I am at +135 and highest I have seen is 2070MHz and drops down and stays level at 2040MHz. Mine doesn't really bounce around. Whats temps and fan speed you using? Finding it tricky to get the right balance on mine. I am at a 1:1 fan speed pretty much and just stays under 70c
The power percentage is relative to the base bios power. i.e if a card is 250w out of the box, moving the slider to 330w is +132%, but if your card is 300w out of the box and you move to 330w it's only +110%
I believe at +125% my asus strix is at 330w - my overclock is +151mhz, where the out of the box boost clock is 1650mhz, so that gives it a new boost clock of 1801mhz. Fan speed is on a custom curve but generally at full load the fan won't go above 65% (I've set to only go above 65% if it gets to 75c, which it never has as I found once the fans go over 65% they start to make this really annoying high pitched sound), for Temps the hottest I've seen is 73c with a room temp of 27c. The "bouncing" I was refering to is based on the load of the card, at 99% load and after several minutes of gaming the clocks are 2050mhz, but if I do something in the game and the load suddenly drops to 80% or something, the clock will go over 2100 and up to 2150mhz, the clocks also go straight to 2150mhz even at 99% load when I first launch my games (maybe because the temps are only in the 40s or 50s)
I often spend time imagine how high I could push it with a 380w bios and a water loop but I'm stuck with the air cooler for now
I put the slider to 125% and max power in HW Monitor shows exactly 330W.
I used OC Scanner which apparently gave me + 89 MHz on the core. On the voltage curve it says + 135 MHz on the top end. Kind of confusing. Why wouldn't it just say + 135 MHz overall. I am guessing, it's add the + 89 on top of the out of the box OC.
Usually I seem to get just under 2100, when first loading up a game.
If the game uses like 200 fps (1440p) the clockspeed will go below 2000 in game. In more demanding games like Assassins Creed or BF5 It goes to just under 2100 on startup, then stays dead on 2040MHz for hours.
I am using a 1:1 fan curve and it doesn't go over 70c.
Loving the performance, but thinking about trying a manual OC to see if I can get any more out. My experience with OC scanner so far is that it gets a pretty much close to max clock as manual, using another card.
Hi all,
First proper upgrade in nearly 8 years, after making the most of my 2500k/GTX580 SLI rig...
Used the same case and PSU from 18 months ago, but everything else is brand-spankers.
Was originally going for a 2070, but a convenient Barclaycard 0% balance transfer deal popped up, so I said "effit".
Rig specs are:
My basket at Overclockers UK:
Total: £2,980.00 (includes shipping: £11.10)
with my Corsair RM750i PSU and the Jonsbo/Cooltek W2 case...
Very much enjoying the almost instantaneous startup and performance boost - I game on the lounge TV (4k/60hz) so it's been a joy to play Hellblade: Senua's Sacrifice at a grown-up resolution.
Looking forward to giving the freebie games a try later - I'm limited to evenings, once kids are in bed, but that'll change once my two year old starts nursery next week (I'm retired and very much looking forward to an empty house 5 hours a day).
Here's my mid-build and "nearly finished" rig - just some cable tweaking and light-hiding to sort, then I can worry about telling the wife how much it all cost...
http://imgur.com/gallery/tBdf6RS
(Edit: I appear to have added two Graphics cards to my basket - I only have one)
Hi all,
Rig specs are:
B.e.a.utiful matey.
I have to fight for the free time to game :D
Enjoy the upgrade. It's a massive one!
https://www.techpowerup.com/253943/...r-blocks-for-nvidia-rtx-series-graphics-cards
My new card https://~ibb.co~/Jcy3r2Q
Welcome and on TROH.:)
The Roll of Honour.
Date 07/04/2019, Make MSI Gaming X Trio, bemaniac, Link
Date 09/03/2019, Make Gigabyte Gaming, Colonel_Klinck, Link
Date 05/03/2019, Make Asus Strix, hobib_ali, Link
Date 20/02/2019, Make EVGA Black, Van Diemen, Link
Date 10/02/2019, Make Zotac Gaming Edition, Vtec9k, Link
Date 06/02/2019, Make MSI Gaming X Trio, mostlynice, Link
Date 04/02/2019, Make Zotac Gaming Edition, scorchisio, Link
Date 02/02/2019, Make MSI Duke OC, VinylRichTea, Link
Date 01/02/2019, Make EVGA XC Ultra, tyler_jrb, Link
Date 31/01/2019, Make Zotac Gaming Edition, nalla, Link
Date 30/01/2019, Make Zotac Gaming Edition, kawarius, Link
Date 29/01/2019, Make EVGA FTW3 Ultra, Parkinson1NX, Link
Date 28/01/2019, Make Inno3D X3 OC, crinkleshoes, Link
Date 25/01/2019, Make EVGA FTW3 Ultra, fantasticCG, Link
Date 23/01/2019, Make MSI Sea Hawk, PhoenixSP, Link
Date 18/01/2019, Make Gigabyte Aorus Xtreme WF, Nocliptoni, Link
Date 17/01/2019, Make Zotac Gaming Edition, Housey, Link
Date 02/01/2019, Make EVGA FTW3 Ultra, RSR, Link
Date 21/12/2018, Make EVGA Black, djay, Link
Date 14/12/2018, Make MSI Gaming X Trio, LambChop, Link
Date 29/11/2018, Make Inno3D X2 OC, Exsurgo, Link
Date 29/11/2018, Make MSI Gaming X Trio, Beer_MonsterUK, Link
Date 29/11/2018, Make Asus Dual, blasterbolt, Link
Date 28/11/2018, Make Zotac Gaming Edition, monkeylover36, Link
Date 17/11/2018, Make Gigabyte Gaming, marlies, Link
Date 16/11/2018, Make Gigabyte Aorus, Sega Mega Dave, Link
Date 15/11/2018, Make Asus Strix, Mayh3M, Link
Date 14/11/2018, Make Asus Strix, Prozn, Link
Date 13/11/2018, Make Asus Strix, ketma, Link
Date 10/11/2018, Make MSI Ventus, AMB73, Link
Date 10/11/2018, Make EVGA FTW3 Ultra, Dirkscooby, Link
Date 10/11/2018, Make Zotac Gaming Edition, Beeney, Link
Date 07/11/2018, Make EVGA FTW3 Ultra, Kaapstad, Link
Date 05/11/2018, Make Gainward Phoenix, Gripen90, Link
Date 05/11/2018, Make NVidia Founders Edition, arrow0309, Link
Date 05/11/2018, Make Palit Dual, jonneymendoza, Link
Date 25/10/2018, Make NVidia Founders Edition, Raiden85, Link
Date 24/10/2018, Make NVidia Founders Edition, CraigN, Link
Date 24/10/2018, Make NVidia Founders Edition, SupraWez, Link
Date 24/10/2018, Make Palit GamingPro, Dumphole, Link
Date 22/10/2018, Make Gigabyte Gaming, XeNoNF50, Link
Date 22/10/2018, Make NVidia Founders Edition, El_MUERkO, Link
Date 21/10/2018, Make NVidia Founders Edition, olliej82, Link
Date 20/10/2018, Make NVidia Founders Edition, ibpalle, Link
Date 12/10/2018, Make Zotac Gaming Edition, rIcK, Link
Date 10/10/2018, Make MSI Gaming X Trio, bignick277, Link
Date 10/10/2018, Make MSI Gaming X Trio, ISilva, Link
Date 10/10/2018, Make NVidia Founders Edition, [Death], Link
Date 09/10/2018, Make NVidia Founders Edition, ltron, Link
Date 09/10/2018, Make Palit GamingPro, Biffa, Link
Date 09/10/2018, Make Zotac Gaming Edition, Biffa, Link
Date 06/10/2018, Make NVidia Founders Edition, layte, Link
Date 06/10/2018, Make NVidia Founders Edition, Rap1D, Link
Date 06/10/2018, Make Zotac Gaming Edition, Gregster, Link
Date 06/10/2018, Make NVidia Founders Edition, Sc00p007, Link
Date 05/10/2018, Make Zotac Gaming Edition, Born_2_Kill_83, Link
Date 05/10/2018, Make NVidia Founders Edition, Strife212, Link
Date 04/10/2018, Make NVidia Founders Edition, inflynx, Link
Date 04/10/2018, Make NVidia Founders Edition, Paladine, Link
Date 04/10/2018, Make NVidia Founders Edition, Safetytrousers, Link
Date 03/10/2018, Make MSI Sea Hawk, krzychowiec, Link
Date 29/09/2018, Make Palit GamingPro, mrozik, Link
Date 28/09/2018, Make Palit GamingPro, Silent_Scone, Link
Date 28/09/2018, Make Gigabyte Windforce, Quartz, Link
Date 27/09/2018, Make Gigabyte Gaming, GordyR, Link
Date 26/09/2018, Make EVGA XC Ultra, spikerules, Link
Date 25/09/2018, Make MSI Duke, Smffy, Link
Date 20/09/2018, Make Zotac Gaming Edition, LegendaryDread, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 2080 Ti.
I sold some crypto, so had money to burn. Bought a new monitor and this - it's a Zotac Gaming Edition
Can't believe I spent this much on a stupid GPU.
<--- Yeah, I'm with stupid :p
Installed
6otJ7q6
Installed
6otJ7q6
The Roll of Honour.
Date 08/04/2019, Make Zotac Gaming Edition, BubbySoup, Link
Hypothetically lads, if I wanted a quiet two slot card, should I rule out the 2080 Ti, and even the 2080? I know the FEs are dual slot, and some of the EVGAs, but I'm thinking they might be too much for an SFF case? What do you reckon - if I want cool AND quiet in a two slot design, should I be looking at 2070 or less?
At last my step up for my 2080 has finished que just paid so XC 2080Ti incoming. oh by the way for any of u guys that have brought the EVGA on or after the 15/1/2019 u can get an extra free game racing/shooter on steam just check out the evga site.
Hy there.Y need some help please. Y have a Zotac twinfan 2080ti ,that y buy from second hand,and it come with the bios from a Zotac 2080ti blower :( The fans are 100% and its quite annoying. Y try to flash the bios,tinking that solve the problem,but y can not flash the bios,it give me error: GPU Mistmach With another nvflash version y try to override PCI id,y give it Y finaly ,but then Error: update aborted. Y try to put the original bios ,not another,and no way...
y use the comands nvflash64 --protectoff and then nvflash64 - 6 xxxx.rom
