The RX Vega 64 Owners Thread
The software used on this forum is stupid.
Half my post is invisible even though it's visible if go to the edit window.
Found this issue on Windows Phone 10 with Edge. Also half the times I posted an image using edge, I got banned because it was perceived as hot linking images.
What ho gentlemen, I'm glad to apply to the ROH.
This gpu rocks, even more with the UV/OC you guys advised!
I did a buy! Happy birthday to me, from me.
Bit concerned with the CPU AIO tubes touching the cards backplate but nothings died yet :)
You are fine. :D
Chop now 70mv from P6 & P7 states, raise the Power settings (under the HBM) to 1000 and set HBM to 1100.
Raise PL to +50% and you are set. :D
Welcome and on TROH.:)
The Roll of Honour.
Date 23/10/2018, Make Sapphire Nitro, iB CoMpL3XiTy, Link
Date 23/10/2018, Make Reference AIO, Adaw, Link
Date 09/10/2018, Make Reference Air, Scott_DFT, Link
Date 25/09/2018, Make Reference AIO, X3T, Link
Date 10/09/2018, Make Sapphire Nitro, Bloot, Link
Date 06/09/2018, Make PowerColor Red Devil, TimAhKin, Link
Date 06/09/2018, Make PowerColor Red Devil, rip-the-jacker, Link
Date 04/09/2018, Make Asus Strix, Boomstick777, Link
Date 31/08/2018, Make PowerColor Red Devil, Hades, Link
Date 30/08/2018, Make Asus Strix, Figo, Link
Date 29/08/2018, Make Reference Air, EL_JOCK, Link
Date 28/08/2018, Make PowerColor Red Devil, WYNIR0, Link
Date 12/08/2018, Make PowerColor Red Devil, nashathedog, Link
Date 18/07/2018, Make Sapphire Nitro, Sumanji, Link
Date 15/07/2018, Make Reference AIO, LtMatt, Link
Date 30/06/2018, Make Sapphire Nitro, Panos, Link
Date 06/01/2018, Make Reference Air, uncivil_engineer, Link
Date 23/12/2017, Make Reference AIO, Nathan S, Link
Date 20/12/2017, Make Sapphire Nitro, nashathedog, Link
Date 04/12/2017, Make Reference AIO, essentialblend, Link
Date 04/12/2017, Make Reference AIO, calken, Link
Date 01/12/2017, Make Reference AIO, neil473, Link
Date 01/12/2017, Make Reference Air, EsaT, Link
Date 28/11/2017, Make Reference Air, Davedree, Link
Date 26/11/2017, Make Reference AIO, Urgentemente, Link
Date 25/11/2017, Make Reference AIO, Rezident, Link
Date 24/11/2017, Make Reference AIO, jimpsar, Link
Date 21/11/2017, Make Reference AIO, LoadsaMoney, Link
Date 14/11/2017, Make Reference Air, pete910, Link
Date 09/11/2017, Make Reference Air, TrixX, Link
Date 08/11/2017, Make Reference Air, acraftygnome, Link
Date 08/11/2017, Make Reference Air, ree, Link
Date 04/11/2017, Make Reference AIO, HEADRAT, Link
Date 03/11/2017, Make Reference Air, nashathedog, Link
Date 21/10/2017, Make Reference Air, Martini1991, Link
Date 01/10/2017, Make Reference Air, sharmanov, Link
Date 29/09/2017, Make Reference Air, Dempsey22, Link
Date 13/09/2017, Make Reference Air, Dicehunter, Link
Date 12/09/2017, Make Reference AIO, Kaapstad, Link
Date 06/09/2017, Make Reference Air, naLor, Link
Date 06/09/2017, Make Reference AIO, tres_kun, Link
Date 06/09/2017, Make Reference AIO, Biffa, Link
Date 05/09/2017, Make Reference Air, Lustral, Link
Date 05/09/2017, Make Reference Air, Synchrouk, Link
Date 02/09/2017, Make Reference AIO, Tinek, Link
Date 02/09/2017, Make Reference Air, AmateurExpert, Link
Date 01/09/2017, Make Reference AIO, Nemesis.ie, Link
Date 31/08/2017, Make Reference Air, Boomstick777, Link
Date 31/08/2017, Make Reference Air, Paul Campbell, Link
Date 31/08/2017, Make Reference Air, shankly1985, Link
Date 30/08/2017, Make Reference AIO, Chewie, Link
Date 30/08/2017, Make Reference Air, Shiari, Link
Date 30/08/2017, Make Reference Air, chaosophy, Link
Date 29/08/2017, Make Reference AIO, BadIronTree, Link
Date 28/08/2017, Make Reference Air, Neutral, Link
Date 26/08/2017, Make Reference AIO, iihavetoes, Link
Date 25/08/2017, Make Reference Air, disi, Link
Date 25/08/2017, Make Reference AIO, djbully, Link
Date 24/08/2017, Make Reference Air, Bonjour, Link
Date 24/08/2017, Make Reference Air, Kmodo, Link
Date 23/08/2017, Make Reference AIO, Dave2150, Link
Date 23/08/2017, Make Reference Air, Roughneck, Link
Date 21/08/2017, Make Reference AIO, diziet, Link
Date 19/08/2017, Make Reference Air, CapitalOne, Link
Date 18/08/2017, Make Reference AIO, NathG79, Link
Date 18/08/2017, Make Reference Air, Chrisc, Link
Date 17/08/2017, Make Reference AIO, DazQ87, Link
Date 17/08/2017, Make Reference Air, Smudge, Link
Date 17/08/2017, Make Reference Air, ChosenName, Link
Date 17/08/2017, Make Reference Air, mattyc123, Link
Date 16/08/2017, Make Reference Air, WhistleBlower07, Link
Date 16/08/2017, Make Reference AIO, nashathedog, Link
Date 16/08/2017, Make Reference AIO, heartburnron, Link
Date 16/08/2017, Make Reference Air, vanpeebles, Link
Date 15/08/2017, Make Reference Air, Morve, Link
Date 15/08/2017, Make Reference Air, Howling, Link
Date 15/08/2017, Make Reference Air, Apache14, Link
Date 15/08/2017, Make Reference AIO, Dianbobo, Link
Date 15/08/2017, Make Reference Air, ubersonic, Link
Date 15/08/2017, Make Reference AIO, AMDMatt, Link
Date 15/08/2017, Make Reference Air, TonyTurbo78, Link
Date 15/08/2017, Make Reference AIO, MDPlatts, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Vega 64.
You are fine. :D
Thanks for the settings, they worked great (tested in TimeSpy)
I'd be more concerned about the Nitro+ literally breathing the fart from the AIO's rad! :p
Same. I could reverse the AIO fans so they're sucking air out through the rad and out the top of the case but then they'd be pulling hot air from the GPU. Could mount the AIO to the front of the case but the front case airflow is dire. Surprisingly temps are actually fine, CPU is at about 50c and haven't seen the GPU go past 75c
On a separate note, I think the GPU is CPU bottlenecked, in FarCry5 with settings on High with HD textures @ 3440 x 1440 I'm seeing FPS between about 48 to 75 (my frame rate cap) but the GPU is very often at about 70-80% usage. I'm using a 3930K @ stock, will see if overclocking it helps.
Well it's not going to hit 100% usage if the frame rate is capped is it. The minimums look CPU limited but they usually are with any CPU, your average frame-rate is artificially lowered by the cap reducing GPU demand.
No, I mean even when the frame rate is below my cap the GPU usage isnt 100% frame rate could be 50 for example and GPU usage might be 80%.
