Congrats! What is the asic quality?
I’ve not installed it yetCongrats! What is the asic quality?
Has anyone figured out what difference that makes yet?Congrats! What is the asic quality?
It doesn't mean too much tbf, but lower asic cards have a lower default voltage which can sometimes be beneficial overall.Has anyone figured out what difference that makes yet?
Yeah that figures, I think my ASIC is about 80...It doesn't mean too much tbf, but lower asic cards have a lower default voltage which can sometimes be beneficial overall.
What GPU are you using? From what I’ve seen the XT/XTX are generally below 60%, some as low as 33%. Mine is 54% which is definitely one of the higher ones.Yeah that figures, I think my ASIC is about 80...
7900XTWhat GPU are you using? From what I’ve seen the XT/XTX are generally below 60%, some as low as 33%. Mine is 54% which is definitely one of the higher ones.
Crazy Unlocked RX 7900XTX Pulls 650W
Also worth remembering I got slightly better graphics scores in that bench than Roman using air cooling and the Nitro with the stock power limit of 467W.Well one thing it does show is that AMD wasn't lying.
Remember a few weeks ago they claimed they could build a 600watt GPU that competes with a rtx4090? Well it's true because this card pushed to 650w scores significantly higher in benchmarks than a stock 7900xtx and it gets to within 10% of the rtx4090's level
Let’s see if this works
Nope they can be a tad thirsty.Ok finished testing and hgihest gpu score I got with Timespy extreme was 16316. Settings to get that was power +15% , 1025mv, 2750 memory. I did not touch frequency sliders , as soon as i touch them the gpu wets itself and it will lose upto 50% of its score, been as low as 7000 points.
One thing I am confused about is board power draw , showing as 443w max and I was not sure that was possible with an MBA card. Is this jsut a reading error with gpuz ?
Could be a faulty RGB bar by the sounds of it. However try flickering the BIOS switch and using Trixxx to see if you can adjust the RGB options in there. Might be RMA time though I'm afraid.Hi, I have tried to sync my sapphire nitro+ 7900xtx card with my main board and it was flickering white, then I switched the header to the rgb controller from my pc case where it worked almost fine, 1/4th of the leds on the card did not light up no matter the effect, then I thought maybe a restart will help and after the restart the lighting was completely gone. I can’t turn it on in Tixxx software, fan check also fails. Tried to reinstall Adrenalin driver and the trixxx software but this did not solve the issue.
Did anyone have a similar problem where the rgb turned completely off?
Ps. I can still return the card today/tomorrow
Sry for bad English
